dweaver
- Dec 23, 2008
Thats OK after the hype dies down I will just continue to enjoy my GR07
I detect a new flavour of the month. I give it 3 months before the GR07 overhype dies down.
Pretty sure I've owned the GR07 for almost three months now. So adding your additional three months, let's call it the flavour of the semi-year!
There is indeed a lot of hype, but I'm not convinced it isn't justified regardless.
Anyway, the only person who'll be able to tell you whether the GR-07 or UM3x is better is you. It's always a personal choice and it doesn't matter what someone else tells you.
Completely Agree. That's the main point.
The two are similar enough that they can provide the same type of musical enjoyment for a multitude of people, but at the same time different enough that it's difficult (if not downright impossible) to name a head-to-head winner. In the end, what you prefer is your preference. It need not be swayed by the opinions of others, GR07 fanboys or the UM3x old guard. Both camps have their valid points, as well as their personal biases.
I've mentioned that since I own the GR07, I no longer have a burning desire to buy the UM3x. However, that doesn't mean that one is better than the other. It merely means that, to me, the two occupy a very similar sonic role in my listening experience. I'm completely convinced that you can't go wrong with either choice. In the world of high-end IEMs, there is never a consensus opinion on the superiority of one over another.
