DannyBai
- Nov 21, 2010
I use it with the TH900 and it drives it very well. I usually have it on medium gain and using high gain, it can get to deafening levels. Great synergy as well.
Cool. Thanks. Thinking of getting a portable amp to do double duty instead of a desktop amp.
DUET I borrowed for 3-5 weeks. Amazing amp. Both are great and the sound signature, while not the same, trends to similar veins. Both drive earphones perfectly, and both have very low noise floors and great control over L/R and balance. So... do you need balanced? Do you need the longer battery life of the DUET? Do you need the compact size of the V? That should be the questions you ask first. Both are great and deserve praise.
The DUET controls hiss very well. In some ways it is ahead of the pure as an iem amp.
The PURE II is a much better form factor and is easier to use. Both have great sound signatures. Both are favourites of mine.
Could current owners of the Pure II please confirm how many hours of burn-in time is needed before the amp settles down. I am using mine with iems and closed back headphones together with my AK120 but I cannot find any difference in sound quality between using the AK120 on it's own or with the Pure II connected. The amp only has about 30 hours running time on it so far.
AK120+Pure2+SE846
Any recommendation for 3.5mm mini to mini cable and earphone cable to improve the sweetness of female vocal?
Now using all original cable and pure2 run in only about 10 hours. Everything is fine for pop and classic.
My VorzAmp Pure II is up for Sale:
http://www.head-fi.org/t/717503/fs-vorzuge-vorzamp-pure-ii-free-shipping
Price is at $465, which is a whole $100 cheaper than MSRP!
