Virtual Dynamics Judge power cable arrived
- Thread starter Patrick82
Zaluss
- Oct 26, 2009
It keeps the bad audio waves away from the good ones.
Oh yeah...
Oh yeah...
Speederlander
- Jun 21, 2009
Brilliant send-up of cabling nonsense.
West726
- Jun 10, 2009
"SEND-UP"? Seriously? Sorry, friend, it's far more subtle. Think as you wish, though.
Originally Posted by Speederlander /img/forum/go_quote.gif Brilliant send-up of cabling nonsense. |
VanQuish
- Feb 6, 2008
Wonderful thread, thanks for the entertainment Patrik!
- Mar 13, 2007
[pretentious masturbatory post trying to show intelligence by regarding the OP as a joke]
kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
- Jun 21, 2001
All of the black things on the cables are magnets. 2 different sizes.
The brass things are not magnets. According to patrick, the magnetic
properties are significant. i.e. several thousand gauss.
Magnets used this way in similar circuits serve to add hysteresis
to the AC signal. Basically as a way to reduce noise around the
zero crossing.
Originally Posted by vcoheda /img/forum/go_quote.gif i don't even understand what those huge cylinder things are on the cable and what purpose they serve. |
zero crossing.
logwed
- Mar 9, 2009
I nominate Gauss for the coolest unit of measure!
Originally Posted by kevin gilmore /img/forum/go_quote.gif All of the black things on the cables are magnets. 2 different sizes. The brass things are not magnets. According to patrick, the magnetic properties are significant. i.e. several thousand gauss. Magnets used this way in similar circuits serve to add hysteresis to the AC signal. Basically as a way to reduce noise around the zero crossing. |
Speederlander
- Jun 21, 2009
How does being "more subtle" make it not a send-up? Perhaps it's performance art?
Claiming to put $500 in vibration supressors under a powerstrip and raving about all the improvements in sound is about as un-subtle as it gets.
Originally Posted by West726 /img/forum/go_quote.gif "SEND-UP"? Seriously? Sorry, friend, it's far more subtle. Think as you wish, though. |
scootermafia
MOT: Double Helix Cables
- Nov 24, 2008
The main benefit of VD gear is that they figured out that powdered metal completely immobilizes the conductors while still allowing the cable to (sort of) bend, this is really effective vibration dampening beyond what textile padding and such can do. Then the various clamps snuff out vibrations at certain points by squishing the metal powder into the wires even harder. The magnets do some sort of sound cleanup duty. Really, the VD cables have a lot more to offer than most out there that I've seen. This cable is overkill for the OP's purposes but I'm sure it could be a valuable part of a super reference setup. With his T-amp and EMU system it's a terrible, terrible waste...while he's maxed out the performance of these items by purifying their power until it's whiter than the robes of God, it's like achieving the maximum F1-tuned status of a Geo Metro.
IPodPJ
MOT: Bellatone Audio
Caution: Incomplete customer orders
- Apr 17, 2006
So eloquently stated, and as true as it gets.
Originally Posted by scootermafia /img/forum/go_quote.gif while he's maxed out the performance of these items by purifying their powder until it's whiter than the robes of God, it's like achieving the maximum F1-tuned status of a Geo Metro. |
Patrick82
Banned
- Mar 1, 2003
I don't think it is overkill for a K1000 system. Perhaps it's overkill for Etymotic ER4P since they are resolution limited, however, the difference in flavor is still easy to hear. I re-wired the ER4P with Valhalla...I didn't get any resolution improvements but I did get the Valhalla sound signature which I love. It's the same thing with Judge, I like the Judge mostly for the coloration I get, and as a bonus I get higher resolution than with multiple Genesis power cables.
I have switched into a speaker setup, I have both Adam A5 and Adam A7. I get more resolution from the cheaper A5 because of lower electricity and smaller driver, but that's only when I use a lot of tweaks to fix the brightness of A5. The same thing was true when I switched dCS sources into EMU0404 USB.
With K1000, Adam A7, and Adam A5. If I can hear huge improvements when undervolting the computer, then the system is revealing enough and will benefit from Judge power cable.
Originally Posted by scootermafia /img/forum/go_quote.gif The main benefit of VD gear is that they figured out that powdered metal completely immobilizes the conductors while still allowing the cable to (sort of) bend, this is really effective vibration dampening beyond what textile padding and such can do. Then the various clamps snuff out vibrations at certain points by squishing the metal powder into the wires even harder. The magnets do some sort of sound cleanup duty. Really, the VD cables have a lot more to offer than most out there that I've seen. This cable is overkill for the OP's purposes but I'm sure it could be a valuable part of a super reference setup. With his T-amp and EMU system it's a terrible, terrible waste...while he's maxed out the performance of these items by purifying their power until it's whiter than the robes of God, it's like achieving the maximum F1-tuned status of a Geo Metro. |
The-One
- Apr 23, 2006
patrick's thread about the adam speakers in the speaker/cables section intrigued me.
this thread however, is just a total mind****...
Patrick82
Banned
- Mar 1, 2003
I moved the Judge a little and bent it on one end to change the position of the power strip 90 degrees. I heard a reduction of sound quality and went to look what was wrong, then I saw that one of the magnets wasn't resting on Magix anymore, I quickly put the Magix back and got more clarity in the music. But it's still not like before. Bending the Judge reduces clarity because it needs to get burned in again for many weeks.
thanks.
thanks.
