Xenophon
- Apr 15, 2013
Still torn between the two.... Leaning towards Taurus MK2 but never know
I had the opportunity to audition the Taurus Mk2 yesterday, though only briefly and with my HE-6 on SE, never listened to the new Violectrics and can only compare with my V200.
Can imagine you being torn because beyond a doubt, quality of both brands is really good. I'd have to listen a lot longer to be sure but with the HE-6 I think I might have a slight preference for the Taurus 2 vs the V200, it sounds a bit more neutral and airy to me. But this was only after a brief audition and using SE only, I'm not sure if the Taurus would have the juice in balanced setups to drive the 6 well (power output in balanced/50 Ohm is a lot lower than in SE). If all other things were equal between the Taurus and the new Vios then I guess lovers of more heft and slamming bass might go with the Vios. This fwiw after a very brief audition, most of which was spent while the unit was warming up (it really makes a difference with the sound) .Curious to read other impressions.
