fdg
Member of the Trade: Lake People
- Oct 29, 2009
@ rx79ez08
There seems to be a little missunderstanding ...
… to make more clear what we are using for volume control inside our Violectric gear:
Inside V90 you can find a nice and small potentiometer with two of the above mentioned resistors in one case.
It is the RK14 from Alps and works quite fine.
Inside all other headphone amps and PRE V630 we are using the good reputated ALPS RK 27. Here you can find each variable resistor (2 for stereo) in a separate housing, so crosstalk is very good. Also there is a 41-detent inside.
We are measuring the channel imbalance at 12 o´clock position. If it is higher than 0.3 dB it will be sorted out.
The first volume control option on V220, V281 and V630 is the remote option.
Beneath other things the volume can be controlled by pushing a remote button.
To do so, we are using a motorized RK 27 potentiometer.
Here a not so little motor through a gearbox turns the potentiometer, visible by the rotating knob. Of course there is a clutch installed so you can turn or stop the knob by hand even when the motor drive is in action.
The second volume control option for V220 and V281 is again made with the motorized RK 27 potentiometer. Same procedure as above. But this time a control voltage is generated and A/D converted to control the 128-step relais attenuator.
Yes, I know, there are more simple and cheaper ways to remotely control the volume.
But that´s the way we go …
By the way, because the volume is attenuated in the digital domain inside DAC V800 the quality of the potentiometer must not be that good. Here we are using again RK 14 from alps.
When there will be an updated version of V800 there will be also a motorized RK27 inside.
In the moment we are seeking the space inside the case to proceed )
Greetz
Fried
Greetz
Fried
