Did you ever see Fried's all silver Audeze cable? Afair he has to remake them for each audio show/fair because there's always someone buying it.
No, I never knew Fried made a headphone cable. And in silver nonetheless?
I know it's not a V281 but it's for a V281.
I received this today from Violectrics:
XLR extender (7 meters long) made at the V281 specification. Thanks to Fried.
So well built.
I will test tonight. I'm in my happy place. I can go back to using the NightHawks and V281 combo.
Interesting. I had no issues with my V281 and my Kassandra DAC and that has 10v on RCA, maybe touch less, but is hot. It sounded great, no distortion or any issues. I ran it like that with no pre or post gain or reduced gain. I had the pot at about 10 oclcok on the LCD4 for normal to loudish level.
I joined the club just emailing back an forth between Author was planning to meet and pick up the amp but didn't feel like driving. I got the v281 coming was wondering about the gain switches.
So I have Verite which are 300 ohms how would I choose the right gain switch? Would it just be volume control or something to do with just sounding better?
I think there is a general consensus that using the balanced headphone output really allows V281 to shine and strut it's stuff. That said, the single ended headphone output is also very very good.
So its more of a SQ thing then getting the right amount of volume like using a high low gain on other amps.1) Always go balanced with the V281 to fully utilize all 4 amps inside.
2) Start with 0db (default) and listen for a few days, acclimate to the sound, get a feel for it, dive into it. Afterwards try -12db and see how that works out for you
