Justin_Time
Unlike home speakers where the nominal impedance varies between only 4 and 8 ohms, headphone impedance can vary from as low as ~ 80 ohm (Focal Utopia) to as high as ~ 600 ohms. It is hard to design an amp that works perfectly with all headphones. It is just as hard to find a pair of headphones that sound good with all amps. Part (not all) of the problem is dynamic damping--the rule of thumb (backed by an analysis I won't bother you with) is to keep the impedance ratio (HP over amp) above 8. That is not always possible with all amp designs and all HPs.
My Apex Teton sounds great with the HD-800S but not so much with the Utopia (too much bloom in the bass). On the other hand, my GS-X Mk2 sounds great with the Utopia but was a little too analytical with the HD-800S. I have not had enough time yet to try the V281 with all my headphones--I have had it for just a couple of months. But so far, there are hits and misses as with the other two amps. I would say it is in the same league as the Teton and the GS-X. Good amp!
