novicez1
- Apr 29, 2016
I think you need to be sure that you make the comparison at the equal loudness.
Anyway you can look at this in the different way.
Lowering the gain leads to slightly less resolution - that's because you hear more sparkles, and less colors.
Setting gain to 0 dB gives you that colors, which make the music lifelike.
You can find more different points of view, but I think what the equal loudness is the key to be less subjective.
The results of such comparison may surprise you
I did volume match when making the comparisons. I'll buy a pair of XLR interconnects later so as to be able to a/b the G109A and V281 on simultaneous output off the RS06.
Shouldn't it be lesser gain = more resolution as adding more gain will inadvertently add more distortion in the final sound?
