Thank you for the quick response and I love your videos.... keep it upNo, each jack outputs a stereo signal
Violectric HPA V280 - balanced headphone amp - impressions and discussion thread
- Thread starter Fegefeuer
Njychen
I am using it now with the Clears and compared it extensively with a bunch of amps like Mjolnir 2 , Cayin IHA , Lyr 3 etc.
It is neutral with a slight tilt of warmth!
How do you like it compared to the Cayin?
Listenisb
How does it compare to Aune S7 pro? Should I upgrade? Driving Focal elex and hifiman Arya with Aune S7 pro and Topping dx7s currently. Very happy with how it sound on Focal but not mush so on Arya.
Fegefeuer
- Mar 17, 2011
What do you like about the Fostex pairing? (which Fostex?) What do you NOT like with the Arya pairing?
Imo the V280 is legitimately an end game solid state amp. Unless you have the power requirements of an Abyss or Susvara I feel like I'm pretty much set with it, and the Vio sounds amazing with the Arya.
There are others in this price range that you can look at. I have a Phonitor E on the way to compare the two for the YT channel but to my ears you really can't lose with the Violectric.
I am considering adding a v280 to my RME ADI-2. Do you think it will add anything to the RME or do you not hear much of a difference between the RME amp and the V280?
the fool
- Feb 17, 2012
Is this amp fully balanced like it's big brother v281?
I hear a difference, but it depends on your headphones. Check this video if you haven't already.I am considering adding a v280 to my RME ADI-2. Do you think it will add anything to the RME or do you not hear much of a difference between the RME amp and the V280?
Loaded question but check this post: https://www.head-fi.org/threads/vio...-durch-balanced.705318/page-249#post-14378632Is this amp fully balanced like it's big brother v281?
Short answer is
gimmeheadroom
Depends on the headphones.
It's the same amp.
Listenisb
I was talking Focal Elex not Fostex. Elex sounds great on Aune S7 pro and Arya can be better or only few improvement compare to my other amps I owned like smsl sp200. I actually have a pair of Fostex th610 and I don't think it's a good pairing with Aune. I didn't like it when I had x7s. ISorry I don't have the fancy words to describe exactly what I don't like. I'm considering v280 bc I really like Arya and want to buy an amp to drive it to it's full potential. I'm willing to upgrade my current DAC as well. I feel like Topping does not have the authority but a nice soft sound. What balance DAC do you suggest to pair with v280? Budget for DAC is below 2000USD. ThanksWhat do you like about the Fostex pairing? (which Fostex?) What do you NOT like with the Arya pairing?
Listenisb
Good to know it sounds great with Arya. Do you have a DAC in mind or used before that matches the slightly warm sound of vImo the V280 is legitimately an end game solid state amp. Unless you have the power requirements of an Abyss or Susvara I feel like I'm pretty much set with it, and the Vio sounds amazing with the Arya.
280? I'm using Topping D7s right now but somehow I prefer the sound from my AK Kann more compare to Topping. Topping uses two 9038q2m and Kann has single 4490.
I bet either will sound great. I upgraded from an SU-8 because I wanted the features of the RME. There's about a $1k price difference there but I couldn't say the RME sounds 5X better.Good to know it sounds great with Arya. Do you have a DAC in mind or used before that matches the slightly warm sound of v
Fegefeuer
- Mar 17, 2011
If you have that kind of budget for a DAC why not take a look at the V590? You will get both a full DAC and the successor to the V281 in one package.
I have owned the Arya for a while and paired it with the US4+ and it was a great pairing. US4+ bass power and sustain really complements the Arya next to giving it more tactility and definition. The Arya is highly capable and scaling very well, the only real nitpick I have is the 5k peak, which doesn't really disturb me but for new headphones we should expect better.
The V281 successor is designed close to the US4+, so of course I'm extrapolating from the Niimbus standpoint. Hope to have a listen to the V590 soon so I can give it a real judgment. Since the Arya buyer lives in my town as well, I'll just invite him over.
I don't trust Aune or SMSL. No offense to budget gear but 99% of them are just designed by spec, nothing more. And they sound this way too. If you want budget gear take a look at Schiit and some of the little manufacturers that don't get mentioned a lot here.
Focal Elex has sharp tactile transients, which is a plus, but pairing them with a THX amp and with a meme DAC should do them no favors at all.
Music Path
Previously known as hm22music.
- Apr 5, 2015
I think the real successor of the V280 will be the V380, considering the PSU implementation, and simpler design. And if the unit goes close to the 2000eur area it will good consideration for people using V280 and external dac. Now the question is how it sounds, does it have the musical/romantical presentation like @Relaxasaurus sais in its video? which i agree. If yes, it would be a great combo.
@Fegefeuer Could you talk about more about the pairing of the Bifrost 2 and RME with the V280/281 since you listened to both. These are two similar priced dacs which are very compared. There is even a tread for it in the new forum called "the headphone community". You said you liked the the bifrost more, could you explain more?
@Relaxasaurus Does the RME signature change much when chosing for example the NOS or slow filter with V280 (more fuller sound)? Does it colours a bit the V280 sound or not?
Hope you still get to make the big Dac comparision including the Bifrost 2 you said you where going to do in the future. Great videos.
Fegefeuer
- Mar 17, 2011
No, the V380 is a DAC/AMP. The V280's successor, the standalone amp, has a different number. You will find out soon.
The RME offers a lot of functions which you should make use of if you buy it, else it's a waste if you don't. Bifrost 2 has better tone/timbre, imaging, better bass definition and power and staging offers much more depth and layering. Real instruments have greater weight and body and you will love the density of their tone.
Bifrost 2 is very bare bones though, only offers 3 inputs and a polarity switch. No pre amp function, no AES. However USB quality is outstanding.
Bifrost 2 is best when listening to Redbook because the closed form filter works best with 44,1 and 48khz.
