OnyX Prime
What dap do you use again?Is there a specific one you recommend?
So I just ordered the PW 1960 2 wire cable. What are your thoughts on that? And how much does the yatono cable retail for?Hybrid silver: Tri silver x6 or Cleo 8w I heard it’s good with the low end and add warmth to thin and light bass iem
Copper: Personally I recommend brise audio yatono (perfect match imo) or asuha (newly introduced, cost/performance choice, very very good according to many in japan)
Using right now: 1960 4w (what I currently have on hand that’s satisfactory. I am looking forward to getting the yatono 8w to replace the pw 1960 4w. May change it to 2pin for my ciem. Honestly, I do not recommend pw audio cable as they are way over priced in terms of cp. try have 1 or 2 cables that are of good quality but still too much imo
Maybe Onkyo SN-1 could be the answer?I tell you this if jvc makes a 10000 headphone Ill biy two right now. Im lazy, I like plopping a headphone on my head, so I sold all my iems. The 10000 os the only iem I would use if I had to use an iem.
I couldn't find Onkyo / Pioneer on this list so most likely SN-1 won't appear in Kowloon Bay later this weekThe SN-1 comes closer to the FW10K. SN-1 has fantastic slightly bright leaning and warm mids that are emotional. Imaging, staging and overall detail is great, though may be too much for some.
Will like to hear more comparison with FW01. Maybe a balanced copper cable will help. Something EA Ares 2 is a start.They are not leaps and bounds better than the FW01 from what I’m hearing right now
Both YATONO 8wire and ASUHA won't work with SU-AX01 without an adapter, IMHO the obvious choice should be waiting for JVC to release their own balanced cables with dual-3.5 plugs.
https://www.head-fi.org/threads/vic...nniversary-model.891366/page-27#post-14767208I couldn't find Onkyo / Pioneer on this list so most likely SN-1 won't appear in Kowloon Bay later this week
http://www.music-union.com/2019/05/13/avf2019音響展-參展商名單/
Cutting-edge artisanal in-ear monitors for discerning listeners. Proudly designed and manufactured in Singapore.
Stay updated on Subtonic Audio at their sponsor profile on Head-Fi.
I decided to put them back on the burn. Right now at hour 480, some of the “shoutiness” has gone down. Basically when someone raises their voice on a song, the way it hits your ears is soft and not as abrupt as before. An example of this is the opening words of this song: “first thing, Monday morning, I’m gonna pack my tears away”.
The bolded normally hits your ears harder with the FW01.
With some (usually older) recordings they sound so magical and open that it doesn’t feel like I’m wearing anything at all. Sometimes like a completely different earphone from the FW01. As good as those are, they don’t have that “open” sound.
As for the bass it is still more restrained than the FW01, but at times can output the same kind of teeth-chattering bass when the song calls for it, so the bass almost seems to come out of nowhere. This is with the single-ended cable.
Then go for the cheaper one, then you go for the expensive one then you ended up paying more. Audiophile logic.Price wise between FW01 and FW10K, getting the FW10K doesn't seems like good value.
