Victor HA-FW10000: 10th Anniversary model
May 10, 2019 at 12:43 AM Post #662 of 1,217
Hour 408: the FW10000’s Bass is damn good, even with the single-ended connection and powered by the SU-AX01. On par with the balanced FW01 if not slightly ahead because of how amazingly tight and low it gets. The sound is that much more complete and just insane.
They’re energetic as hell though. Voices and instruments can at times get a little too sharp for comfort. It’s a sharpness that really jumps out at you. Swapping the cable tames it.
May 10, 2019 at 1:03 AM Post #665 of 1,217
May 10, 2019 at 1:06 AM Post #666 of 1,217
Focal utopia neautral cold , stellia warm but faulty.
What do you think of the PW Audio 1960 2 wire cable?
I am thinking of pairing it with my CL2.
I saw on one of threads that you had the 4 wire, could you help me with the signature if possible?
May 10, 2019 at 1:08 AM Post #667 of 1,217
Well made but it brings warmth to the sound. So if you have a very bright iem it can help
May 10, 2019 at 1:09 AM Post #668 of 1,217
Do you know of any other copper cables that are in the same performance bracket?
I will be putting my order in soon, and it's kind of hard to make a judgement without a first hand listen.
May 10, 2019 at 1:11 AM Post #669 of 1,217
Pmd
May 10, 2019 at 1:17 AM Post #670 of 1,217
Anyone can recommend a full size closed headphone that’s close to signature of FW10000?
Closest I came across is ZMF Eikon but that thing is quite heavy. Sound marvellous though.
May 10, 2019 at 1:32 AM Post #672 of 1,217
Th900 and denon 9200
May 10, 2019 at 1:42 AM Post #674 of 1,217
May 10, 2019 at 1:44 AM Post #675 of 1,217
All piercing. Haven't heard the Stellia but the other three. Too sharp for comfort can be another way of putting it.
Stellia more bass, not quality bass, muddy mids, weird treble.
