Vali 2 tube rolling
Aug 29, 2019 at 10:26 PM Post #4,456 of 6,436
Aug 30, 2019 at 5:15 AM Post #4,457 of 6,436
Aug 30, 2019 at 8:45 AM Post #4,458 of 6,436
Nope. I made 3 of the same length with the same wire and same connectors. One with all 4 wires, one with no 5v wire, and one with no 5v and no ground wire (only the + and - signal wires). That last one didn't work at all, and in fact I think it was @Paladin79 that backed that up over on the DIY cable forum quite a while back -- the ground wire has to be there for the cable to work at all (and apologies Tom if I'm confusing you with someone else). The cable with the ground wire but less the 5v wire worked fine, but I couldn't detect any meaningful sonic difference between it and the full 4-wire cable at all. But that was just one trial with one particular wire and one particular assembler (those USB pins are a supreme PITA to solder to even with a 22 gauge wire), so I won't rule out the possibility that a difference could exist with a different wire, construction, and/or assembly expertise.
I do not recall talking about the ground wire in USB but that is possible. I built @Ripper2860's cables for sure but just followed what he asked for. I did not have the exact equipment he was using to check them out.
A word about cables...The most you can hope for with a cable is to maintain the signal that enters the cable. A cable itself or any variation thereof should not cause that signal to sound better than what you have enter it. Cables can vary in resistance, capacitance, impedance etc. but most effects you can bring about by adding or changing things are not generally good ones IMHO. You can add a different gauge wire or solid versus stranded wire to increase conductivity and lower resistance. If you bi-wire speakers, it can cause a slight difference in signal level.
You can trap out certain frequencies but i will not get into that right now.
In wires that handle a digital signal, the same holds true except you are dealing with the equivalent of 1's and 0's, and type of wire and shielding can be more important but once again, you are trying to preserve what is there, not delay it, or clip the signal. If you are going to spend $400, spend it on the equipment because a lot more is happening before or after the signal hits a USB cable. Use quality cable for sure, a cable where you are guaranteed one piece will be identical to the next you buy but do not expect a lot of sound differences there.
Back to tubes, some folks love, and some hate the Melz 1578 but in some testing done over the last couple days, people were more likely to pick it out compared to other tubes including some very good sylvania, tung sol, ken rad, whatever. Right now with current votes it is the favorite among the group but maybe for the wrong reasons. It is distinguishable, the mids are more forward sounding and jump out at you IMHO. Maybe that is why people notice it more and give it some very good scores. So far I have had no one say the highs are harsh, but terminology in audio can be tricky to replicate. Some say the other seven tubes sound similar, and this tube just sounds so very different. Right now this is not serious testing, that will happen whenever the tubes come back from Schiit and there will be no limits set on which tubes the Melz might go up against. The results should be more well defined.
Aug 30, 2019 at 8:47 AM Post #4,459 of 6,436
I'll double check my facts. Maybe even the no - didn't work with Mimby. Tom actually made me 3 if you include the NORMAL USB and my recall may be flawed.
I'll also A/B the cables and see if I can hear any diff. I added a linear PSU to the D50 about the same time so maybe that's what I heard. Now that I'm aclimated to the sound, I'll be better equipped to assess.
It has been a while but was the improvement supposed to be that you are eliminating the 5 volt line and any noise it might induce? I know at the time you mentioned a reason for doing this. I am just trying to follow the theory. Would better shielding give the same result?
Aug 30, 2019 at 9:23 AM Post #4,460 of 6,436
Yes. PCs are electrically noisy and the thought is that noise can be injected from the computer into the DAC via the unused 5v + line, sounds plausible. Since my DAC is externally powered, I figured it was worth a try. Not really sure what audible difference it has, but it doesn't hurt.
Aug 30, 2019 at 9:39 AM Post #4,461 of 6,436
Yes. PCs are electrically noisy and the thought is that noise can be injected from the computer into the DAC via the unused 5v + line. Sounds plausible and since my DAC is externally powered, I figured it was worth a try. Not really sure what audible difference it has, but it doesn't hurt.
Yes, I have done component level repair on PC’s and their power supplies. I also taught some switch mode power supply theory.
I have some more thoughts on tubes that I will try to relay later on.
Aug 30, 2019 at 10:54 AM Post #4,462 of 6,436
Ok here is a theory on tubes, and it is my theory and my opinion, nothing more.
I believe we like things that are out of the norm, that might be harder to obtain. I have been told that Russians do not consider the Melz 1578 that great of a tube, and would rather buy Sylvanias. Americans have a lot of access to Sylvania, RCA, Tung Sol etc. yet here we are looking for specific Russian tubes, or British tubes. Occasionally there are some US made tubes we think the world of but some recent tests are a prime example of my theory.
A friend thought most of the 8 tubes (6sn7 equivalent) I presented him in a blind test sounded similar, then he got to the Melz and it was so different, it stood out to him. He picked it as his favorite. Last Saturday I went through a bunch of Amperex from different periods and most all of them sounded harsh and raspy, I basically just plugged them all in without looking at the types very closely and my favorite was one that probably sounded the least like the others, but I liked the sound. It may have been the cheapest, and least sought after yet, it sounded so different to me, and I was not getting the harshness I disliked in the other tubes, with my amp and DAC setup.
Do I think the overall SQ of single triode tubes is better than some really nice dual triode 6sn7's, doubtful, but they sound different. The spacing is nice. Will a 7n7 rank towards the top in my testing? Or a Foton ribbed plate 1954? Possibly but once again, when you listen to a lot of RCA's and Sylvania's, they sound very different so to me that could be part of it. I like to do blind testing because you can eliminate some of the preformed ideas. That does not mean a tube like a GE would finish toward the top, there are tubes that can be stand out in a bad way.
If you have access to a lot of Brimars, is that your tube of choice if you are British? Just some thoughts, nothing else.
Aug 30, 2019 at 10:57 AM Post #4,463 of 6,436
I've been aware of their existence for the last 4 or 5 years. Have no idea how long they've been in business though. That cord scares me just by looking at it, but they do have this stuff that is kinda cool. It's messy, but it's not expensive and makes an audible difference depending on where you use it. Nothing night and day, but noticeable:
http://madscientist-audio.com/graphene_ce.html
And then there's this cable. I've seen postings from people going into nearly lunatic raves about it, and some calling it the equivalent of a $10 Belden from Amazon. I haven't tried it. I don't have the technical knowledge to support or refute their marketing claims, but what I *do* know is that hell will have entered a new ice age before I spend $400 on a USB cable. :grimacing:
http://madscientist-audio.com/bmusb.html
I am staying away from cable discussions for one simple reason. I had been reviewing a set of speaker cables which cost almost $3K, but the review came to an end. @Paladin79 terminated some good quality cables and shipped them to me at no charge. I attached the speakers and plugged into the integrated, and the sound was as good, certainly not worse. He had explained what a cable does, and what a cable could not do.
That was all I needed to hear, and I submitted my resignation to the "Do expensive Cables make a huge difference?" debating society. Does good quality cable work better than speaker wire that looks like an extension cord? Maybe, I don't know. I do know that quality runs of cable don't need to cost an arm and a leg.
Aug 30, 2019 at 11:11 AM Post #4,464 of 6,436
--cut-- I like to do blind testing because you can eliminate some of the preformed ideas. That does not mean a tube-like a GE would finish toward the top, there are tubes that can be stand out in a bad way.
I am not British, but discovering Brimar valves from the early 1960s has certainly opened my eyes. I have the 1951ribbed Foton and the Melz 1578, and they sound great on the Vali 2. Rolling 6sn7 into the Valhalla 2 was not a good experience.
@Ripper2860 suggested a pair of the Brimar CV4033, and I bought a set. Oh, Boy, Howdy! They were $90 for the pair at Tubemonger.com and they are the best sounding valves for my headphone rig. Our friends at Vivatubes.com had a similar offer, the CV 4024 for sixty a pair. I am using them as my daily listeners with the CV4033 in reserve. I pulled up the sign that read, "We Buy Cheap Tubes" and have no desire to look back.
I am still very new to tubes. My Vali 2 arrived in December. It has been a learning curve, with no regrets. Once you find a set of valves which work and make the best music, the desire to keep looking wanes fast.
Aug 30, 2019 at 1:44 PM Post #4,465 of 6,436
I am revisiting my tube collection in the new setup with aune T1. Now going through 6C8G. Some sound gorgeous in vali 2, but do not quite work in aune technically (blurry sound on higher loads). Ken-Rad VT163 sound absolutely awesome, and do not cost a lot. So do National Union VT-163 with support rods (btw, see a pair at good price https://www.ebay.com/itm/2-NIB-6C8G-Tubes-National-Union-Simular-to-6F8G/264437192805).
Otherwise, found 15 pieces NOS NIB CBS Hytron 6J5 $5 apiece and bought them all. They also have loads of Ken-Rad JAN6J5M which I want to try, and more than a 1000 pieces EC8010 from Siemens and Philips, but these I cannot buy all :triportsad:.
Aug 30, 2019 at 3:00 PM Post #4,467 of 6,436
@Ripper2860 just wanted some free cables. His only rationale was....free. You could have sent him some 30 year old lamp cord with dry rotted insulation falling off in chunks and he’d never have known the difference, assuming you’d encased it in some pretty sleeving. :laughing:
Aug 30, 2019 at 3:33 PM Post #4,468 of 6,436
Frankly, I cannot recall if I paid for them. I have purchased cables from Tom in the past, so the assumption that they are free would be incorrect, sir.
Aug 30, 2019 at 4:05 PM Post #4,469 of 6,436
I do believe Ripper did pay for them but my memory is a little hazy. He may be the person I offered 9 different shades of blue to and he still wanted the jacket color to be half way between the first and last shade of blue. It made me want to give choices like Henry Ford, the color is black, that is the only color, go away and leave me alone. I could be thinking of someone else though. :smile_phones:
Aug 30, 2019 at 4:08 PM Post #4,470 of 6,436
That would NOT be me. The nit-pickiness about shades of blue sounds like @bcowen and his aversion to Duke's basketball program and their winning ways. :wink:
