sbtourist
Yes. Compatible tubes with the Vali sans adapter should be as follows: 6CG7, 6FQ7, 6BK7, PCC88 (7DJ8), ECC88 (6DJ8), E88CC (6922 and it's many family members-I'll go in to this), 6N1P, 6N2P, 6N23P, ECC85. I am probably forgetting one or two of the more "niche" ones or sub versions.
7DJ8 (PCC88 in Europe) are identical in almost every way to a 6DJ8 (ECC88). The main difference is they technically use a higher heater voltage (7V) as opposed to 6.3V of the "normal" 6922 substitute. They work fine though...I use a 7DJ8 variant (Japanese Matsu****a) in my Lyr 2. If anything it will last longer, but some people say they don't like the 7DJ8 sound. I say it's up to you!
On the topic of 6922 variants...technically the 6922 (E88CC) is a high end version of the 6DJ8. Their internal structure is almost always different from the 6DJ8/7DJ8, but they should have nearly identical properties. Between the US and Europe, there are MANY variants. Some are highly sought after and command insane prices (Simens Cca for example).
You can read this article on them: http://www.audiotubes.com/6dj8.htm
I wouldn't buy in to all of the hype he has for some types of tube (he wants to sell you them remember) but it at least makes a little more sense of the nomenclature.
This is a great answer. Thanks!
