I'm a basshead but I don't like it (well ok the bass is fine but yea mids & highs aren't).
I think there was a saying going around in this forum which I find extremely accurate in my case:
The casual listener craves lots of bass
The experienced listener craves highs / clarity (V-shape)
The audiophile craves forward mids
xD I've been at the "craving bass" stage and then moved onto V-shape stage and these days the mids are also just as important as bass. I really want as forward / "in-your-face" vocals as possible to go with a boosted bass, the highs should never be emphasized beyond the mids like in PRO900 in my book. I've been at the V-shape stage but I'm past that now and can't enjoy that anymore haha. "Music is in the mids".
Well I prefer mids, but an emphasis on the upper mids and more on the analytical side (the SRH940 does that very well for its price). Forward vocals is probably more what I would want, not necessarily forward mids; singer taking front stage, guitars/piano/clashing cymbals/other mids behind the singer, bass guitar and pedal drum in the back.
This might be of interest to some people:
http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
So, I don't know....but, does the 8~9 db bass boost of the M-100 (and Fostex TH900, etc), mean, that amount of bass will be present only when the music calls for it, or that it will be present every time?
If the music has those frequencies, it will mean it will be played relatively louder than other sounds. The ideal, typical audiophile curve is supposed to be flat from 0 Hz to 1 kHz, then slope downwards at a steady decline from 1 kHz and beyond.
Though this term is usually thrown around in this community, I consider neutral to be this ideal curve; everything is, theoretically, the same in volume.
Example (graph from Innerfidelity):
LCD-3
Compare that to the TH900 and the bass is elevated quite a bit more:
Though as mentioned before by others, an elevated bass response is acceptable for on-the-go situations where outside noise often destroys any accurate bass response.
Which leads to another point, the M-80's did not isolate outside noises very well if I recall correctly. Hopefully the M-100 will be better at that.
