RPGWiZaRD
- Jan 31, 2010
According to Val earlier, the M100 measured 8dB+ at 100Hz compared to 1kHz and +9dB compared to 2kHz. This is aprox 3dB louder than that of M80 which measures with around 5~6dB boost in bass, it should be slightly closer to M80 than PRO700MK2, well quite in-between, similar to Q40 probably which has a good amount of bass, not too much and not too little for a basshead's perspective to impact on mids/highs too much. From my experience 9dB or so is the optimal bass quantity vs quality ratio goes at, well ok Fostex TH900 also measures around 9~10dB bass boost and it also manages to keep the bass more than nicely controlled but it's a lot expensier and probably has quite a lot of "R&D" behind it too as there's extremely low THD noise in the bass (=clean).
At least I'm happy if also these units which we will be able to buy soon has a 8~9dB or so boost in bass, that's exactly what I'm looking for when paired with a digizoid ZO amp. Ampless 8~9dB wouldn't still quite satisfy my bassy needs but paired with digiZoid amp this is a perfect starting point and the amp further enhances the bass quality too besides strengthen it which I wouldn't be able to get out of a too bassy headphone such as PRO700MK2 as it's too bassy to begin with.
Fair enough. Regardless of how tight the bass is though, nearly all positive reviews rave about the bass, as is the case for basically all basshead cans.
If anything, the M-100's bass will be more like the M-80 than what I perceive the PRO700MK2's to have in terms of quantity.
