Just a reminder from the
Posting Guidelines:
IMO discussion about whether headphones are good or bad is pretty useless without discussion of what music and listening volume that experience was derived from.
I agreed to the admin.
Different headphones plug into different source gave different results.
You can discuss but not bash headphones, it might be it don't works well with your source.
No one have the same source and equipment.
Completely agree with Currawong. I write reviews and try to establish my bias, musical preferences, types of volume levels I listen at as part of my reviews and then explain why a headphone works for me or not. I rarely state a headphone is bad or good without giving a thorough explanation why I feel that way.
I can definitely add my kudos to Currawong as well. Very often I add the words, "to me," "in my biased opinion," "I can/can't notice...," etc., to my posts. Headphones are the ultimate
personal listening experience, so of course everyone has different preferences.
I know sometimes I can get enthusiastic about my equipment, firmware, and custom presets for it. When I say stuff like,
"This is so awesome and it blows everything else to smithereens," please note that I'm being subjective in terms of my own tastes, preferences, and uses. I also tried listening to a lot of other headphones at my local Hi-Fi shop, and none seemed to have the kind of high sensitivity and huge response to low-end sub-bass EQ'ing that my M-100s have.
Personally, I get the most excited about
Rockbox firmware because it is so incredibly customizable, easy to use, has a +12 dB bass boost feature, and in addition to that (separately), has a customizable 10-band EQ with a range of +24 dB to -24 dB along with a volume precut option for it, and Rockbox enables me to create a virtually infinite number of
EQ presets using Notepad on my PC and saving them as .cfg files, where I can organize these EQ preset files into their own folders and sub-folders for easy navigation and can quickly and easily change them on the fly while listening to an album on my iPod. Furthermore, I especially get gung-ho about this because I can upload all these presets to the Internet as a .zip file and post a link where all other users of Rockbox firmware can download these and use them on their own players! Being able to share the countless hours of all my hard work spent on these EQ projects and all the joy that comes from it -- with other Rockbox users who appreciate it -- is a great feeling.
Anyway, as far as listening goes, I usually crank my portable headphone system up quite a bit with the sub-bass throbbing, and do this with all music genres. I mostly listen to happy, sappy, bubbly dance-pop music, but also hard and soft rock, country-pop, lounge music, and occasionally a bit of classical, jazz-pop, or hip-hop.
But sometimes I listen at low volume as well, where I flip the gain switch on my
Cayin C5 portable amp to "low," in order to eliminate the small hiss noise from the amp that's otherwise audible when listening at low volume. At low volume, I also use a bigger bass increment and a higher treble sub-category in my
EQ presets (for that particular song) than I normally use, and it sounds awesome, too.
And yes, the source equipment is absolutely important! For example, earlier this evening I was listening to the country band Lady Antebellum, using the "Lite" and "Ultra Lite" midbass categories in my latest EQ presets. It sounded
excellent through the M-100s with a throbbing low-end, nice beat, decent highs, and good soundstage without coloration of the upper midbass / lower midrange.
But then, for contrast, I turned off the bass boost feature in Rockbox, switched off the bass boost on the Cayin C5 amp, and turned off the EQ in Rockbox and set everything to flat. The result? Most of those same Lady Antebellum songs -- and especially the ones where "Ultra Lite" had sounded the best -- sounded really colored, seriously lacked depth and soundstage, lacked crisp highs, and almost sounded like it was being played through a wall or a narrow tunnel. To put it simply, Lady Antebellum didn't sound good
at all through the M-100 without an EQ and bass-boost features.
Of course, there's plenty of other songs by other artists that sound good through the M-100 without any EQ'ing -- it just depends on how it was recorded.
That's my take on all this.
Anyway, I look forward to posting more pictures of going walking with a friend with both of us wearing M-100s (Matte Black and White Silver) while listening to the same song together -- each with our own separate Cayin C5 amp (and volume control) -- with some awesome city skylines and scenery in the background! 2016 will be a happy, happy year.
