Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
Any alternatives to V-Moda's 1/8" to 1/4" Plug Adapter V2? Not sure if mine is defective, but it outputs a mono signal if I plug the headphone cable all the way in it, so have to find just the right position for the stereo sound. Got a standard 1/8 to 1/4 adapter but its not compatible since V-Moda's cable jack is 4 pole.
Which cable are you using? Do you have more than one to test with?
I have the V-MODA Audio Only Cable and it works fine with V-MODA's adapter. Then again, my adapter is the one included with the Crossfade LP. You could always get a cheap adapter from anywhere that is still compatible.
