Solrighal
- Jan 27, 2005
vodka
Or McEwan's Champion ale. Stickier though.
I've no idea how to get the plug out though. Big pliers?
vodka
vodka
guys, what amp do you think this headphones would benefit the most? probably something that ups their mids. I was thinking of buying an e12 but want to know some other opinions
Definitely not the e12 (mont blanc), it's too sensitive and too loud. Try the E17 or if you're up for it, the Verza.
Thanks a lot ! I'm not buying The amp right now but i can wait. Thoughts on dragonfly?
Dragonfly? 3 words. Overpriced overhyped junk. I mean, their cables are decent, but the soundcards are junk. You could save the money for a high end DAC instead of being stuck with a terrible USB stick. The way I 'be an audiophile' is to buy a new mid range product (when I got into iems I got the Shure SE215) and then I jumped straight into the high end. No point buying dragonfly, it's the purchase you'll like for a while then you'll find a much better product and regret buying it, depends on your current set up if you'll even like it to start off with.
Thanks man. I'm already familiar with the v-moda brand so thats why i'm choosing it. What do you think is a good high end dac that costs that much? (Its 100$-150$on amazon)
Honestly, in my opinion, if you are going to buy any external DAC/Amp for the M-100s it should be the Verza. It was tuned with the M-100s in mind, so it really is the only thing that I have found that makes them sing. Sure you could adjust the treble and bass on the E17, but really it isn't necessary for the M100s to sound good. Lately I've been playing the M-100s directly out of my Nexus 5 with little issue. Naturally I still have my Arrow 4G and Cowon J3 combo which is great. But the extra power that I gain from the Arrow doesn't really add anything to the sound. The only thing I occasionally do is increase the treble by a notch to offset the bass a bit (since I can't lower it like I would on the E17).
That said, I agree with Existence on buying practices. I went straight for broke hitting midrange to higher midrange for my purchases. Going in low to things that are not well regarded is kind of a risky business. The lower end I have is just my Clip Zip and Koss KSC75, which are both highly regarded as bang for buck items, and are so cheap that it is hard to regret buying them. At 100~ it becomes harder. So choose your purchases wisely.
OMG... I would STRONGLY recommend NOT getting the $600 Verza for for any pair of V-Moda headphones unless you are a really really big fan of the company or have a big disposable budget.
Spending $600 on a portable amplifier for a pair of $300 or less headphones makes no sense! The headphones are responsible for 80-90% of the sound quality. The amplifier maybe has like a 10% impact on your sound. Your budget should really go the other way around with $600 on your headphones and <$300 on your amp. You should never really be spending more than 50% of your budget on external equipment (dac/amps) unless you have already reached that $1000+ flagship mark with your headphones & obviously have so much money, your budget isn't an issue at all.
Of course, if you feel differently that is fine. I have owned several M100s and paired them with a $80 and $450 amp. They honestly do not scale up very much at all with increased amplification. The V-Moda unamped basically sounds exactly the same as a V-Moda hooked up to a $500 amplifier. My personal experience, YMMV.
