Dec 10, 2009 at 9:29 AM Post #106 of 266
Originally Posted by spore /img/forum/go_quote.gif
I only have limited experience but Panasonic FC or FM will be good replacements. you can try them out and see which one you prefer. Thanks.
Ok. But what capacitor i should replace with Panasonic? C22 or C27?
Dec 18, 2009 at 10:53 AM Post #108 of 266
Could you consult me about few more questions.
I decided to replace signal path capacitors.
For C147, C151, C51, C47 i found only 3300pF 63V polypropylene capacitors.
1. Is it crytical to have 3900pF or i can use 3300pF?
2. 63V - is ok or should be more?
3. Polypropylene capacitors are the best for C3, C4. But 47uF polypropylene is very big. So i will use ELNA Silmic II and i should setup it with right polarity. How can i find where + and - is? Or better to use Nichicon Bipolar.
Thanks in advance
Dec 22, 2009 at 1:43 PM Post #109 of 266
filin44
1. you can try and see how the sound changes and if you like it or not.
2. Higher voltage rating is better. It must not be lower in values than stock voltage rating.
3. From my past experiments, -ve should be facing the pcb board edge when viewed from the top of the board.
Hope this helps.
Jan 1, 2010 at 6:10 PM Post #110 of 266
Originally Posted by Pricklely Peete /img/forum/go_quote.gif
Totally concur with this statement. A dedicated high quality PSU will make a huge difference.
Peete.
My results do not support this. I bought a big ol' power supply with 3 amps continuous, 13V, and the VDAC doesn't sound any better. I can barely tell a difference. Of course, I WANTED to hear a difference, but the honest truth is, I didn't.
This is the supply that I bought:
Samlex America RPS1203 3 Amp Regulated Linear DC 12 Volt Power Supply
Any comments are welcome. Thanks,
Hukk
Jan 1, 2010 at 8:20 PM Post #111 of 266
Originally Posted by Dutchamps /img/forum/go_quote.gif
Hi
First of all i respect your tourney to avoid the output caps.
Just jumper it
Is this safe?
People here are saying, "it's OK to remove the output caps of the VDAC as long as your preamp has input caps, because the preamp's input caps will prevent your speakers from getting DC" --
but, what if your preamp's volume control is BEFORE the preamp's input caps? Won't this send a ton of voltage to your preamp's volume knob, basically frying it?
Hukk
May 1, 2010 at 7:24 PM Post #114 of 266
Hello,
I modified my V-DAC using OPA4277, OPA2134, adding some Rubycon 1000uF and OSCON 100uF capacitors. I used also more powerfull supply-1000mA. It was wastly improvement reg. bass quality, details and transients. However entering this forum, I hoped to find schematic of V-DAC, but only some photos was available. Any of you have any idea where this schematic can be found?
May 25, 2010 at 8:53 AM Post #115 of 266
Hi I did some reverse engineering and have full schematic of this DAC. But without most of the values, as I did not need them. Schematic is little bit messy as I did not clean it up but again it was not necessary for my needs. I was just redesigning output stage (not only changing op-amps, but also caps and resistors) and supplying it with high quality shunt regulated power supply. There are some stuff left and I am waiting for few parts from farnell now to continue. If the results will be satisfying I will post them here. I will be also tuning USB receiver part as the implementation in V-DAC is really crappy. Beside this V-DAC is really cool device.
Jun 1, 2010 at 4:26 AM Post #116 of 266
I want to mod my V Dac so that it sounds colder and more detail because i´m having a tube pre. My pre sounds very warm somethime  too warm for me. Thats why i want a cold source to make balance......any suggest ?
Jun 7, 2010 at 7:33 PM Post #117 of 266
Try OPA627BP in second stage (you need browndog adapter), and maybe LME49740 on first one. I am actually running 2xOPA1612 on first stage and LME49860 on second, but I am aiming to neutral and transparent sound. Analog stage in my V-DAC is powered by two independent SuperTeddyRegs at +/-17V. It was best improvement. Much, much better than changing opamps and caps. Now changing opamps gives much more differences and it is easier to find a differences. Sound is very smooth, transparent, full of details and with well defined bass. Lack of bass control and sometimes screaming highs was main drawbacks of V-DAC for me. Now it is a better source than NAD545. When going for cold sound and trying very detailed output opamps (like mentioned OPA627BP) be careful. With low power quality (unfortunately this is the case for V-DAC. Use heavy decoupling after switching DC converters or better use separate ultra low noise regs) these opamps may sound screaming, and make you tired very fast. Power, power, clean power for analog stage - this is the best mod for V-DAC. Now I am wondering how I was able to listen to it before....
Jun 28, 2010 at 10:26 AM Post #118 of 266
HI All,
On the subject of power supply, I have used a QED Positron (originally designed for use as an upgrade for the QED Digit DAC).  The is rated at 15v DC - the Digit "required" 12V.
The tranformation in sound was immediately obvious, power authority and dynamics. It shows how poor the original supply is!!
I suppose these can still be found secondhand and should be very expensive (at least until folk realise what they can do for the V-DAC)
Regards,
Jim
Jul 17, 2010 at 4:40 AM Post #120 of 266
Hi there,
I'm new here and I'm interested in upgrading my V-DAC.
Would it be helpfull to replace all the condensors for instance with Wima folie c's?
Not adjusting the values of components but just replacing them of those with a better quality?
Thx,
Jordi
