USB DAC and seperate headphone amp OR combo USB DAC headphone amp
Aug 13, 2012 at 10:19 AM Thread Starter Post #1 of 12
EndersShadow
I have a big dilemma on my hands. I am trying to get a good nice hi-fi setup for listening to lossless audio files. Without getting into the nitty gritty, I plan to use a min-itx computer as my source of totally lossless files as a standalone unit (i.e. no networking at all). I want to send the signal out to a Asynchronous USB DAC to a headphone amp to a set of headphones (most likely Beyer DT-770’s). Here is where I need some help. I am looking for either a USB DAC and a separate headphone amp, or a combo unit. I need them to be ~200-250. Used is totally an option.
If going with a USB DAC headphone amp combination unit, I need it to have volume control on the unit, rather than controlling playback through the computer’s volume (ie Musiland Monitor 02) as I plan on having a 7” touchscreen to control everything and would prefer to not have to constantly mess with the volume through that. I don’t need the unit to be super portable, and having an external Powersupply rather than using USB for power is actually preferred.
I am aware that with this low of a budget there will be some compromise on the setup, and I am ok with that for now. Eventually I plan to move to better units, but for now I want to get the computer built setup and running with high quality files and then after a couple months upgrade to a better headphone amp and/or DAC On my radar right now is the older Yulong U100 and that’s honestly about it. I know there is the HUD-MX1, and the Audinst HUD-MX1 and the Audinst HUD-Mini, but I believe the Yulong U100 has been said to be better than both those others. I like the Schiit Asgard but buying one of those used leaves me with almost no cash for a USB DAC.
Looking forward to whatever suggestions folks have for me.
Aug 13, 2012 at 10:53 AM Post #3 of 12
nuforce HD ?
Aug 13, 2012 at 2:16 PM Post #6 of 12
With your budget, it does not necessarily mean compromise. I recommend NFB-15.1. All you need and then some. Just a few dollars above your budget shipped.
Cheers!!!
Sent from my iPhone using Tapatalk
What's the difference between the 15.1 and 12.1? I don't see anything obvious. I like the fixed output option for sure. Though I must say the front on the 12.1 and 15.1 look pretty ugly compared to the 16 :frowning2:
Aug 13, 2012 at 2:54 PM Post #7 of 12
Dac Destoryer, USB-DAC, sell for around $50-$55 on eBay.
Muse 6N11 tube headphone amplifier, sells for $50 on Amazon.
Will need an RCA to RCA cable to connect them to each other.
Aug 13, 2012 at 3:05 PM Post #8 of 12
Maverick Audio TubeMagic D1 DAC w/ GE 5670 Tube: $219
Hard to do better in this price range, and it's versatile enough (includes a preamp) to build a system around. I liked its headamp with the low impedance/efficiency K701.
A used Matrix Mini-i would be a step up ($300 new), but the USB input is its weak link. Which means that you can further improve it later with a decent USB to spdif converter. IME it works well with higher impedance headphones like the HD600.
Aug 13, 2012 at 4:02 PM Post #9 of 12
ES, I don't own the 12.1. If you click on the NFB-15 on the site, it states the upgrade.
The front is lovely. Lol
I own the 15.1 & 16. The 16 I move all around the house and plug various sources to it since it's battery powered. The 15.1 is larger and stays stationary.
Aug 13, 2012 at 4:28 PM Post #10 of 12
Thanks. Looking at the NFB-5 as well. It's a bit better I believe than those other units. Might pop on it.
