regal
- May 27, 2006
See below, this is how you power the clocks with the LiFePO4 battery. To remove the inductor cover it in flux and heat up the metal ends left to right back and forth till it pries off. Clean up the pads with flux and solder wick, use a magnifying glass to make sure there is no solder bridge between the left and right pads.
Connect the positive terminal of the battery to the RIGHT pad. Soon I will have part numbers for a case that fits the hiface and battery holders perfectly, have a wedding to go to first. Will figure out the CPLD as well, but below will get you 90% there.
