regal
- May 27, 2006
It's troubling that the stock HiFace seems to do better with my NOS Constantine and Stello (with upsampling off) than it does with the North Star which was specifically purchased for the usb needy, secondary, laptop rig.
Now that I've covered all the things you don't agree with, what's your take on the small clock - large clock issue. Do you think the small clock is sonically inferior to the large clock or do you think, as some have said, that there is no sonic difference between the two?
USG
First keep this in mind, for the average DAC under a few grand in price it is much easier to implement NOS properly, that is one of the reasons NOS became popular.
As far as the clock issue, see the clock thread for my take on it. I will never buy another Hiface product until Mr. Marco is "redeployed" some where else.
Rankin's claim would be 8 bits shifted where 1 bit is 6dB, so that would be a 48 dB difference! Obviously the hiface volume difference some of you are hearing isn't the difference between load headphones and a jet taking off (48 dB), so yes his claim is a bit off from the science of digital audio, I'm sure he would clear up his statement to be exactly as I said, some DAC's don't handle the padding correctly.
As far a the treble tilt, I just don't hear it at all. And the fact that my DTS decoding receiver decodes a DTS encoded signal from the Hiface proves that it is a physical impossibility, I'm sorry but I will never by into that one. I have seen DAC's handle volume poorly usually as I said in getting the format correct from the reciever chip, so I believe you on that but you are blaming the wrong device.
