ble0t
- Nov 5, 2004
Take a look at this: http://www.tentlabs.com/Info/Article...decoupling.pdf
It is also noted in various datasheets and has been discussed on this forum that you want to have the groundplane directly underneath the DAC and as full as possible...a search on 'groundplane' and 'DAC' netted some results for me concerning that...
Originally Posted by ezkcdude What's wrong with having GND go through vias? It's not a signal line. How else would SMT components connect to internal GND planes in multi-layer boards, anyway? It seems to me your design will be a lot simpler if you dedicate the bottom side to a large ground plane. |
