slwiser
- Jun 23, 2001
^Thanks for the comparison..somewhat reading between the lines it would sound like the XM5 and Predator are almost equal in performance.
Originally Posted by oogabooga /img/forum/go_quote.gif I asked James at PD if the crossfeed introduces a delay or phase-change in the music that is being "crossfed" into the other ear, or is it a mono/stereo mix? His answer: I've compared the crossfeed on the XM5 to that via Canz3D (software implementation, which does the time-delay) and found that the Canz3D sounded a bit more like loudspeakers in that it moved the soundstage in front of me. However, I did notice a slight change in the music as well - it just sounded different. I can't really quantify it, except to say that the mids and trebles sounded a touch muddy. Sorry, but I've never heard a Meier or Headroom crossfeed, so I can't comment on those. IMHO XM5's implementation doesn't change the character of the sound in any way, which I think is a big plus. I've found that I've left the XM5's crossfeed on over the past few days, and it's made for a more pleasing listening experience (my IEMs spend about 8 hours in my ears each day, and this Xfeed alleviates the harshness of having a techno beat come out of only one ear!) Now I'll apologize if I use the wrong terminology, but to sum it up, I think that Canz3D sounds more like loudspeakers in front of me, in that it moves the soundstage forward, while the XM5 xfeed simply collapses/narrows the soundstage a bit, while retaining the "in the head" soundstage typical of headphones. |
Originally Posted by slwiser /img/forum/go_quote.gif ^Thanks for the comparison..somewhat reading between the lines it would sound like the XM5 and Predator are almost equal in performance. |
Originally Posted by oogabooga /img/forum/go_quote.gif Larry (or anyone else for that matter), since you're using a Mac and an XM5 as well, I need to ask you - have you experienced ANY problems with the USB DAC? I've been having this intermittent static problem where my music suddenly converts to very loud static, and the only way to fix the problem is to disconnect/reconnect the XM5. The problem occurs about once/twice a day |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Boy, you ARE good. There are differences in their sound, but the Predator, XM5 and TTVJ portable Millett hybrid sound like they are from the same family; while the XM5 and TTVJ could be brothers and the Predator is the cousin. Likewise, the Pico, D3 and D2 Viper with LM4562/LM6172 sound like they are in the same family. The Nuforce sounds like it is in the Meier Family with Headsix and 2MOVE. Also, the Predator is in medium gain at 11:00 o'clock while the XM5 is in low gain at 11 o'clock for similar volumes, and TTVJ has a fixed gain. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif The D3 is a more open and spacious sounding amp like the Pico, while the 2MOVE is even more forward to my ears than the Predator. |
Originally Posted by kostalex /img/forum/go_quote.gif Larry, I bet you know how unreliable the audio memory is. It seems that it lets you down with 2Move. I had compared Pico, D3 and Move recently:
Originally Posted by Skylab /img/forum/go_quote.gif Larry, you can borrow my 2Move any time you want. I keep it around as a reference, but I don't use it much - my main portable amp is the iQube. While my experience with "Nick20" stealing my Caliente has meant I almost never loan equipment out, you and MrArroyo are exceptions due to the fact that you do such great reviewing work AND have borrowed and returned equipment to me before |
