soltenebrum
- May 19, 2012
From what I heard, as sound quality, Xduoo x10 > Shanling M2 >= Hidizs AP100
Oh well, thanks for the reply. You've just made it a wee bit harder for me to decide now
Oh well, thanks for the reply. You've just made it a wee bit harder for me to decide now :confused_face: . I was initially considering M2 too, then I read about the high output impedance, also it has less power and smaller battery, looks fricking beautiful though. I'm assuming X10 has a low output impedance.
That is want... reviews and comparisons between the x3 and the x10.
Plus, any dap that I get has to have two card slots that take at least 128gb.... my two 128gb cards that I am using in my x3 are both nearly full.
@Holypal
Between X10 and XD-05 Which is better? XD-05 is slightly cheaper but I want to mod it with burson v5i amp.
One is a portable player, one is a dac/amp. They have similar signature. PC+XD-05 has better sound than x10.
T
Thank you mate, I know XD-05 is dac/amp but I'm going to use it via Otg on an Android device.
It's a easy one. X10 has the same amount of details as Fiio X5, and it's more musical. DSD hardware decoding. Two SD card slots. These are all M2 and AP100 lack of.
The X10 is now on the xduoo website; http://www.xduoo.com/xduoo/En/ProductView.Asp?ID=19
Mine is on the way since yesterday. Just can't wait for it!
I skipped on X3 due to the reported issues and if I'm not mistaken they are yet to be addressed by xDuoo. It kinda worries me. Also I don't think I'll be listening to a lot of DSD, rendering the second MicroSD socket a luxury rather than a necessity.
I was under the impression that they were scheduled to release on November 30th. Where did you order from?
X10's sound is a big upgrade to X3. The second SD slot is good when you have many lossless albums.
I guess the guy didn't extend the processing time, so the seller entered a fake tracking number.
