Anaxilus
- Mar 12, 2010
It better be battery-powered otherwise everyone w/ a Nokia USB-2-go could be lost as potential customers.
A couple more pics to check out with added exposure...
Edit. In the bottom left.. is that a switch and led with a word starting with 'CH'? So hard to see. Might have a battery after all?
Looks nice! And I can also say that it looks like a "CH". Looks like the word charge, it wouldn't say power and definitely not a gain or bass boost switch.
Also where did you get these pictures?
Yeh I reckon it is a charge switch. It won't need a gain switch and the power and bass boost switches seem to be on the front.
I wonder why UM said it wasn't portable? Unless it's much bigger than it looks or as heavy as Thor's hammer it should work?
I just used the pic in the first post and increased the exposure.![]()
Again like I said, It can't be used with an iDevice unless paired with a CLAS... But if it does have a battery, then I would assume it would be able to work when paired with a DX100 and the like.
However I guess nothing is certain until the final specs are released...
*huge*!
Update:
SPDIF input supports 24BIT/96KHz
Optical and Coai inputs also support 24BIT/96KHz
Update:
I must say that, at that price, I would've expected it to go all the way up to 192khz, especially considering that it's intended for use with a laptop, where we're the most likely to have our uncompressed hi-res files stored.
