490952
- Jan 31, 2018
Just tried the ME1s with the MandarinEs Symbio W tips. Compared to the JVC Spiral Dots, they sound very similar actually. So, any difference in sound I point out here, is very minimal. The Symbio W seem to give the ME1s a slightly punchier bass and improve the separation by a bit. I could more easily tell where each instrument is. The Spiral Dots, on the other hand, seem to sound just a bit smoother, which makes it more enjoyable listening to vocals.
Comfort wise, they both are pretty amazing, but since the Spiral Dots are softer, they have the slight upper hand. Only slightly though.
The Symbio W seems to fit the ME1s a lot better though, since the Spiral Dots often keep sliding further into the ME1's bore once you plug them in your ear, which renders the actual spiral dots useless. Some rubber o-rings would probably solve this, but I haven't found any that would fit the ME1s.
In the end, I still can't say which one is better though... Somehow, the smoothness of the Spiral Dots makes me switch back to it, but at other times, I wish it had the imaging of the Symbio W.
