Unique Melody Bone Conduction Family (MEST&MEXT and their siblings) Announcement and Impression Thread.
Feb 1, 2021 at 1:59 PM Post #1,651 of 7,333
I have found that the largest stock foam tips give me the best bass. Dekoni does nothing for me. Xelastic are very comfortable, but lose the majority of the bass. Spinfits and Dots lose the bass too. I ordered some Final Type E, should be here any day now.
A VERY tip dependent IEM.
Symbio W Foams are my preferred because that happens to me with the bass as well re: those tips.
Feb 1, 2021 at 2:12 PM Post #1,652 of 7,333
Feb 1, 2021 at 2:13 PM Post #1,653 of 7,333
Are THESE the ones?
I'll admit, I'm not a fan of foam tips, but I did notice the top end and soundstage expand with the OEM foam tips.
Yep those are the ones! They're a mix of foam and silicone and a good fine line if you don't like foams.
Feb 1, 2021 at 2:35 PM Post #1,654 of 7,333
If you dont like the faoms inside the tips. You can just take the foams out. They aren't adhered to the Symbios. You can just flip the tips upside down and just take out the foams. Actually way more comfortable that way.
And you can use those foams on other tips too for experimentation so keep them around just in case but otherwise. I take all the foams out of mines.
Feb 1, 2021 at 2:50 PM Post #1,655 of 7,333
Ordered. Thank you for the recommendation.
Feb 1, 2021 at 2:55 PM Post #1,656 of 7,333
I forgot to note, I use a size smaller than normal for these ones. They fit a little shallow (at least in my ears) and a size down helps get the deeper fit required for the MEST.
Feb 1, 2021 at 3:13 PM Post #1,657 of 7,333
Thanks. I got the S/M/L kit since I have never used them before. I also found that true with Xelastic tips, to go down 1/2 to 1 size down.
Feb 1, 2021 at 6:16 PM Post #1,659 of 7,333
Feb 1, 2021 at 6:24 PM Post #1,660 of 7,333
Feb 1, 2021 at 6:41 PM Post #1,661 of 7,333
Feb 1, 2021 at 11:57 PM Post #1,663 of 7,333
Final Type E tips are pretty good. If the OEM foam tips are 100%, Final Es get a 95%. Missing a tiny bit of low end rumble and top end sparkle.
Feb 2, 2021 at 1:37 AM Post #1,664 of 7,333
My Mest arrived yesterday, so I was reviewing all my tips, to see which one I liked the most.
It is definitely an IEM that I enjoy more with the Final E or the silicone Sony. Precisely, the Sony size L have finally been chosen, because in this case they are more comfortable for me to be shorter, getting the same or even better sound.
Feb 2, 2021 at 11:04 AM Post #1,665 of 7,333
