Unique Melody Announcements, Impressions, & More
Jan 23, 2023 at 11:59 AM Post #541 of 553
Actually we are not in disagreement :)
"The key difference from what has come before is that switch to an all-BA low-end in the Maven Pro so there is less of a sub-bass peak and more of a mid-bass punchy emphasis."
That being said, a universal version's performance can differ given you are using tips instead of a shell fit, and tips' performance will vary a lot and may not seal as well either.
Actually there is, because I wouldn't even give 7 to this iem. A strange idea of a top sound when it is dry and almost lifeless. It's my opinion.
Jan 23, 2023 at 12:00 PM Post #542 of 553
7 to the universal version?
Jan 23, 2023 at 12:14 PM Post #544 of 553
Yes, this opinion for universal version.
Will be interested to hear the universal version then in March and see how it differs. What tips were on it when you tried it?
Jan 23, 2023 at 12:24 PM Post #546 of 553
I always use only Azla SednaEarfit Standard or Short.
Oh I find them quite bright, normally if universal its Final E, SpinFit or foams.
Jan 30, 2023 at 12:07 AM Post #547 of 553
Feb 9, 2023 at 5:48 AM Post #548 of 553
Apr 3, 2023 at 9:43 AM Post #549 of 553
Ordered an on the way. I'll shout into the ether all about them.
Did you ever get your set? Still seems to be nothing online about them (good or bad). Any good?
Apr 3, 2023 at 10:08 AM Post #550 of 553
Depends what you like in a bud. I saw someone running the Nuratrue Pro on -2 immersion (bass) setting the other week. This would probably be for them.
My impressions on the below link.
https://www.head-fi.org/threads/goi...soon-or-are-we-there-yet.861024/post-17430108
If they Improved the build quality and fixed whatever the hell they did to the bass (10mm dynamic driver that feels like a 2007 budget BA) then I'd give it another chance as the bone conduction was really cool.
Despite the asking price I could live with the cheap build quality, but not the bass, hearing it was just frustrating as I've heard the same driver in a 6 and 7mm size perform waaaaay better.
Apr 10, 2023 at 6:45 AM Post #551 of 553
Review of the custom version of the Multiverse Mentor is published with comparisons to Krypton 5, Maven Pro, and the Sharona :)
https://headfonics.com/unique-melody-multiverse-mentor-review/
Sep 25, 2023 at 10:23 AM Post #553 of 553
I got UM MEST MK2 recently and I was wondering how to tell if the bone conduction driver actually works and if it does, does the shell have maximum contact with the skin.. should I feel any vibrations while playing audio? Can't say that I do really and I wonder if I have a faulty unit.. ta in advance
