aldinho878
- Sep 23, 2015
I am considering getting the ls50 wireless to use with a MacBook pro via USB. If you use the USB connection, the amp and dac working is the one from the kef speakers, not the laptop itself correct? Would USB be the best way to get the highest quality sound from these connected to a MacBook? Also as far as adding a chord mojo or Hugo into the setup, would it provide better sound, or should I stick to the internal Kef dac/amp? Thanks
