power
- Jun 13, 2010
http://www.cityclouds.de/2011/01/free-album-das-kraftfuttermischwerk-–-am-ende-der-kirschallee/
Hmm..heres a question.
Anyone aware of a set of closed headphones with the SQ(Highs/Mids/Lows/Soundstage) of the PRO900's, with a punchy bass you can "feel", but have no noticeable leaks and decent isolation?
I don't have the Pro 900 yet (they're on their way and should be here by the weekend) but from what you're looking for, the Sennheiser HD25-1/II would fit quite well. Punchy bass, neutral but pleasant mids, detailed and crisp highs, and on top of all: excellent isolation. Bass and isolation are really top drawer; just amazing for the size. And they're built to last with pro applications in mind. Very compact and almost impossible to destroy - even when you try hard. Easily driven with no need for an amp. Two - minor - downsides, though: The headstage is not that extended and the pressure on the ears is significant and may be a nuisance for folks who have a problem with that. I have three pairs. Two are in use by me and the third one by my 12 y. old daughter - for drumming.
Senn HD25-II are very good portable/DJ headphones that have great isolation for a headphone (can't match IEMs) incredible for a supra-aural, however their sound signature does not compare similarly with the Pro900 and the SQ is not in the same league IMO. It is probably not a good idea to make comparisons against the Pro900 until you have had some headtime with them. And if you have had headtime with them, then you have very different ears to me to advise someone that HD25 is similar to Pro900 with better isolation.
I've tried the HD25's before, wasn't really impressed :/ I also much prefer circum-aural over supra
Right now I have my gaze on the HFI580's & DT770s. I'm just afraid as to how much the DT770s leak, so I asked a comparison with the PRO900's leak-wise. C:
I have both, but I don't know about leaking. Is there a way I can test the leak for you?
Scytus said:/img/forum/go_quote.gif
I have a feeling that you'll love the Pro 900.
Great bass (if not more quantity than the HFI 580s, then definitely higher quality).
Mids sound good, highs are sparkly, and for a closed can, soundstage is damn impressive.
