200poundsofamp
- Jun 10, 2011
With the 680s if you put it all on a stage the guitar and lead singer are definitely at the back, but to my ears they're more present than the m50 and hp700 which both have that distant sounding midrange you're talking about. The metallic timbre is true though, I like it for guitars but it hurts it a bit for vocals.
That's a really good suggestion. OP if you want one headphone to do it all I still recommend the 680, it's the "more toned, less bassy version of the 580's" you're looking for. I've never regretting getting it over the 780s, they aren't lacking bass or treble at all to me.
In regards to the Ultrasones, the midrange is recessed, so vocals will seem really distant and buried by the instruments. I have a hard time listening to rock music on Ultrasones, especially because of their metallic timbre. I've not heard the 680s, though so I'm not sure if the same holds true for those.
My advice to you, look at your listening habits, and see which genres you spend the most time with -- and then pick headphones which suit those genres conceding that they may not work fantastic with genres you don't listen to as often. If you listen to equal parts rock and hip-hop, I'd personally take your $200 budget for the SR225i, and then buy a $80 SR60i and a $130 Ultrasone HFI-580. All bases covered.
