luvdunhill
- Mar 22, 2006
Brian:
This is JT related, but I figured it would be okay to post here. I added a switch + resistor to my JT that I am using to level-match two sets of headphones. Kinda nifty. I figure "volume presets" will be something that might be in the uber-controller, but adding a tactile switch and a re-programmed PIC might be able to do this same thing perhaps? I was even thinking about adding another pot and a switch between the two... which brings me to my next question:
Do you think you could share the Alpha pot part number, as I have panels cut to account for the locking pin and need to order another 5k pot
Also, I'm supposing that it's hard to find a place to supply less than 100' of that 10-pin ribbon cable... I cannot find less at Mouser at least.
edit:
ooh, I'm assuming this cable should work:
Flat Ribbon Cable Gray 28 AWG IDC 10 Conductor 25 ft. - eBay (item 200197678096 end time Mar-05-08 08:26:10 PST)
Thanks!
Originally Posted by BrianDonegan /img/forum/go_quote.gif Phoenix Contact numbers 1935161 and 1935174. In the US, available from Mouser and Digikey. |
Brian:
edit:
Thanks!
