- Mar 26, 2013
The hype train from the discovery thread leaks into other threads all the time.
Stay updated on headphones.com at their sponsor profile on Head-Fi.
How is the build? And what other iems would you recomend?Get Duoza then. I don't think T2 fit your requirements.
I've just never seen this kind of advertising bombardment before on Head-fi.. could be exclusive to the budget iem from China thread?
Whats a very good hybrid iem, that will have bass that rumbles but still stays very clear? My budget is $150 dollars but would prefer to spend $100 . I want a earphone that can compete with iems twice or three times the priced and I mainly listen to edm,rap,dubstep & hard dance. So I need something very energetic and fun sounding but at the same time clear and detaild.
Perhaps the desire to have a hybrid or certain type of iem is too strong in some. Plenty of VG single driver IEMs that get less wrong than many of the multi drivers.
Well, at the risk of twister6 saying "I told you so" I've fallen out of love with my T2 as well....much to admire, especially the intimate mids, but ultimately after spending more time with my A83's, the lack of sub-bass, soundstage and sparkle has the T2's packaged for RMA. The channel confusion also didn't inspire great build confidence, and I had one channel go out briefly although only for a few seconds.
In the same price range, can anyone comment on the dual hybrid BGVP DGS100? Or is the double dynamic Douza the object of desire at this price point?
It could be the side vent that they are using for this ? Dont you think, there is a side vent closer to the dynamic driver, and when i tried taping it up, there was a slight boost acrossmthe whole spectrum, very slight
Sub $150 you say? Other guy just recommended like $200-300 headphones, probably useless info for you. Here are my current considerations:
Fidue A71 (~100)
Kef m200 (~100 depending on where you go)
Ath CKR7 (~130)
Ath IM50 (under 100)
Pretty sure all of these would work, but the reviews of the a71 seem to fit your preference the best
Fidue A71 (~100)
Ath CKR7 (~130)
Dont forget im70. Since i have im70, does anyone want a brieft comparison ?
