What the!!! I know I can trust Twister's words but is going to burn my wallet. Have heard many praises of CKR10 from you. Now that you say Duoza is better than CKR10, I'm gladly surprised.
ZA is the best : D
Woah woah....me myself is very much interested in ZA iem....had a go at Tenore...which is an excellent iem...me like the sound signature very very much but getting over the build quality which to me is a bit flimsy(me is a bit rough on iem..used them while riding me motorbike) ...no doubt in me mind Duoza will be good too...hype is good...the trick is getting on the right train...Cheers
Hype on....Muahahaha
Edited...also like CKR9...but bit too rich for me wallet...haha
Yeah, I'm ZA-shy as well since my encounter with the tenores. The douza looks fairly well built though, and even seems to have strain reliefs! It might be worth waiting a few weeks though to make sure nobody encounters the dreaded TTS (although waiting might be tough!). Anyway, I guess I've used up my allotment of OT for the day...
I should have a more updated impression tonight, got T2/Titan1/DuoZA on burn in since last night. So far got 10+ hrs. Not too much changes with DuoZA (bass tighten up), T1 (upper mids/treble tighter and more controlled now), but T2 is starting TO SHINE!!! YEP, the balance between low end and mids/treble improved! Upper mids/treble opened up with more details and clarity, yet still smooth, and bass became tighter with a nice rumble starting to peak through and quantity improving by at least a few dBs. It is still skewed a little more toward mid-centric performance, but not so prominent as it was 1hr out of the box. Looks like their dynamic driver really needs some burn in, I would guess at least 50-60hrs. Based on T2 vs T2 Pro announcements, I'm also assuming that T2 higher frequencies will probably stay smooth while Pro will be brighter/airy due to a different set of BA drivers (obviously, at higher cost).
Keep those burning in. After enough burn in I'd like to know who takes the trophy.
And an opinion once again regarding whether Duoza beats CKR10 or not.
Comparison of two dual dd IEMs makes sense, but not with hybrid in the mix. So T2 against A83 or Altone 200 or Titan 1 (damn, that one sounds like hybrid, but obviously it's not) is a valid comparison, the same for DuoZA against CKR10 or IM50.
Justinzanyo: Thaks for this preview and your initial thoughts.Can you comment on fit / seal / isolation? I am considering these for active use and if the fit is fiddly (the one downside to my Fidue A83's) or the IEM doesn't stay reasonably secure and with decent isolation while exercising, I may need to scale back my excitement.
