Regarding the mobile version.
For me the biggest issue is that I use IEMs mostly BT on the go, so none of them on the list, and also they don't support gapeless playback either. Keep in mind this is an early access version, and they need your feedback to make this better...
Thanks for the feedback, all. I know the True-Fi mobile app is still 'early release,' but it sounds like it still has a long way to go.
Too bad! The glowing reviews True-Fi has gotten makes me very curious to try it out. But I very seldom use my PC for listening to music. Really need a mobile solution -- and one that streams Tidal as well as Spotify.
Some people might call me a heretic for saying this, but the Sennheiser HD700 sound awful right out of the box, but completely transform with this software. I actually liked these better than the far more expensive HD800S after using True-Fi. (Keep in mind that the 800S sound waaaaay better out of the box than do the 700. And because the HD800S are a superior headphone OOTB, they don't benefit as much from the software. But, yes, I stand by my statement that the 700 can sound better after using True-Fi than the 800S sound with or without the software.)
I cannot get True-Fi to work with Audirvana 3.5.x and my Oppo HA-1 DAC/Amp, via my MacBook Pro. Even turning off "exclusive access" in Audirvana, per True-Fi's directions, does not work. It's either the Oppo or True-Fi. True-Fi does work with iTunes and the Oppo, however. Any suggestions?
On mobile (LG V20) I cannot get any decent volume to my Senn 800 headphones through Tru-Fi, even when cranking it to the top. But when I use the Senn 800 on regular apps (Neutron, Spotify, UAPP) I get plenty of volume with zero issues.
