BobSmith8901
- May 5, 2015
Yes but Topping says that you shouldn't use other cables because it might not work, and it doesn't! I've got cables but as soon as I try any other USB to micro it doesn't produce any sound thorough the DAC! It only likes the micro to USB it came with. That's why I'm asking if there's a specific one that people know works.
I've just tested a couple of random USB A to micro B cables and they both work using a variety of programs--Jriver, TIdal desktop app and Winamp.
An intact off-the-shelf standard USB cable should work with your NX4. I don't know why Topping says that you shouldn't use other cables. As far as I know all of these cables are standardized.
Make sure when you're connecting the cable that you've connected to the DAC output (I know obviously....), but also check your computer sound output (that it's selecting the NX4) and also check the Topping control panel that the volume is up and the Topping driver is installed properly.
Since you mention that the connection is iffy at the DAC port but not the charging port (you have to move it around a bit on the DAC port to maintain the connection) it could be some hardware issue like the NX4's DAC micro-USB port and the original Topping cable is able to get the connection at times, while the others can't get it at all.
