Hello, sharpi31.I received my NX1s today. Looking at Toppings frequency response graph the bass is >2db down at 20Hz. Sure enough this appears to be largely due to undersized coupling caps between the volume pot and gain stage (1uF into 9.4Khz resulting in a -3db point of 16.9Hz). The good news is that there is no DC bias on the coupling caps, so it should be possible to bypass them (rather than find some way to replace them with larger capacity caps within the small amplifier case). I measured less than 1mV DC offset on the outputs with the caps in place - I'll short out th coupling caps and remeasure, to ensure the level doesn't become problematic.
It's worth addressing this issue (by bypassing the existing caps or replacing with larger ones) as the phase response of the amp is compromised significantly above the -3db frequency. The normal rule of thumb would be to set the coupling caps to have a -3db point of 1/10 the lowest frequency you're aiming to reproduce (so 2Hz if you want clean 20Hz playback).
Update: all works fine with iPad Pro source and bypassed coupling caps. I'm measuring 0.5mV and 0.6mV on the NX1s outputs. Bass definitely bigger and tighter (not over the top, just less softened).
Since I'm not very knowledgeable in electronics, could you do a step-by-step instruction on your Topping NX1s modification?
Mark with arrows on the photo, what exactly needs to be changed?
Thank you.
