EdgeOfSound
I've just received mine today as an upgrade from the iFi CAN. It's definitely an upgrade. I also don't hear any noise with my Beyer DT1990 Pro even at max volume.
All is forgiven !Just took delivery of a Topping DX7 pro
I only have B&W P7 wired at the moment ( waiting on the Sennheiser 560S )
First impressions are confusing
Some songs sound great , others not so good
I had a Dragonfly cobalt with the same cans and to be honest some songs sounded better than the Topping.
Using Tidal Hifi and Amazon HD from a iPhone and MacBook with USB.
Hoping some better headphones will sort things out .
If not it’s going back.
All is forgiven !
My 560s turned up and the Topping/ 560 combo sounds bliss in everything I play , I’m hearing stuff I didn’t know was there. Only thing is, I play a 192 track and it shows 44 when using USB from a MacBook. Works fine on the phone !
In the mac you can change that, per song, otherwise if you use audirvana or an itunes bit perfect plugin, it can be solved and the sample rate will change automatically for each track.All is forgiven !
Im using Amazon HD but it does the same with Tidal and Apple Music .In the mac you can change that, per song, otherwise if you use audirvana or an itunes bit perfect plugin, it can be solved and the sample rate will change automatically for each track.
Thanks !Yes, but, have you checked on the Audio MIDI Setup in your mac, if the system is actually changing the used sampling bitrate or not? because maybe the dac is good on showing 44.1, if the system is using 44.1 all the time, no? have you checked that already? just wondering, to verify it is a problem in the device and not the system.
Thanks! yes I just set it to 24 bit /192 kHz seems to be changing with the source nowYes, but, have you checked on the Audio MIDI Setup in your mac, if the system is actually changing the used sampling bitrate or not? because maybe the dac is good on showing 44.1, if the system is using 44.1 all the time, no? have you checked that already? just wondering, to verify it is a problem in the device and not the system.
Ok thanks , so when I play a 44.1khz track it just displays 192khz ? Is this right ? (MacBook) Same with the iPhone , just doesn't change with tracks
Think the problem is with AmazonHD , I play through Tidal and the display changes with the track bitrate , This is on my iPhone , Downloaded Audivarna and that changes with Amazon and Tidal on the MacBook . Guess I should ignore the bitrate and just enjoy the music ?! Although its nice to see the correct format being displayed .
So when I go into settings, there is one for the DAC , Which one do I have it on ? I tried both but couldn't tell a difference . ASYNC or SYNC
