$145 for a pair from their store I believe.
Topping DX7 Pro - DAC and balanced headphone AMP with ES9038pro and Bluetooth 5.0
- Thread starter Head-Fi'er
EdgeOfSound
Hi. Anyone here have experience playing swapping opamps in DX7 pro?
Like burson opamps https://www.bursonaudio.com/topping-dx7-pro-burson-v6-opamp-upgrade/
Cheers.
If you understand mandarin I think this guy had a go.
EdgeOfSound
Cheers.
I wonder if it still fits in the case after the upgrade.
Wondering the same. But more curious about the sonic improvements.
I'm currently using my DX7 Pro in DAC/Pre Amp mode with an A90. Is the D70 worth considering or is that $419 better put towards headphones? I'm currently using Sony Z7M2 and HD 660s.
Definitely towards headphones imo. Dx7 pro is already a very transparent DAC.
cirodts
- Jan 27, 2016
If I go into the topping with optical cable from my DAP "dx220", does the sound come out in balanced form from the xlr amp and 4.4mm output on the front side?
Miiksu
- Aug 28, 2013
I think I'm going to Burson V6 classic because I just want to know If I can the the tube amp vibes and still getting a decent dynamic range.I got now some nostalgia vibes and I want again to feel tube amp warmness and strong dynamics. Is it bad idea? Or should i just buy seperate expensive tube amp?
iMongui
- Jan 25, 2017
I can pull the trigger on this unit for 400€ brand new, I want an endgame desktop solution and I think that this one its perfect for this purpose, what do you think guys?
Miiksu
- Aug 28, 2013
That is a steal. Take it. My unit costed 800€ with the tax and still a good value.I can pull the trigger on this unit for 400€ brand new, I want an endgame desktop solution and I think that this one its perfect for this purpose, what do you think guys?
On the first page of this thread it's mentioned that the output impedance is a bit high. What does that mean? I used to have the DX7S but not the Pro. My headphones currently are the Sennheiser HD6XX and 58X.
Miiksu
- Aug 28, 2013
It may alter headphones sound if the impedance is more than 1/8th of the headphone. But planars are uneffected on this because they have flat impedance curve. DX7pro output impedance is 10 ohm.On the first page of this thread it's mentioned that the output impedance is a bit high. What does that mean? I used to have the DX7S but not the Pro. My headphones currently are the Sennheiser HD6XX and 58X.
https://diyaudioheaven.wordpress.com/tutorials/how-to-interpret-graphs/impedance/
iMongui
- Jan 25, 2017
Well, the person who's selling it told me that he bought on aliexpress, its on a pristine condition, just used for a few hours but in any case, as far as I know, there is no warranty or not a good way to manage it, but in any case, he offered me a final price of 380€, I wanted to buy thx 789/a90 but I think that its much better than the ones I mentioned right?That is a steal. Take it. My unit costed 800€ with the tax and still a good value.
Miiksu
- Aug 28, 2013
A90 has better quality than DX7pro headphone amp section and it cost you alot more when you take the THX 789 DAC to it. For that price take the DX7pro and be happy with it It's so cheap that you even probably not regret it if you plan to upgrade to better.Well, the person who's selling it told me that he bought on aliexpress, its on a pristine condition, just used for a few hours but in any case, as far as I know, there is no warranty or not a good way to manage it, but in any case, he offered me a final price of 380€, I wanted to buy thx 789/a90 but I think that its much better than the ones I mentioned right?
JKDJedi
Did the Bursons fit?I think I'm going to Burson V6 classic because I just want to know If I can the the tube amp vibes and still getting a decent dynamic range.I got now some nostalgia vibes and I want again to feel tube amp warmness and strong dynamics. Is it bad idea? Or should i just buy seperate expensive tube amp?
