Miksuu: and other readers and DX7 Pro appreciation! If not lovers... as I am right now
Do you find the Low Fequency extension position discreet op amp makes any difference or not really?
Would you like me to mail you two pieces of the Spark 3602 Op amps for comparison? We would appreciate your opinion as well to add to the already impressive list of discreet op amps you already have. You could have them by next Wednesday or sooner. ❤ So far I am not willing to part with the Vivid v6... but maybe in a few more days when the other Discreets arrive.
I only want to try all four together for up to a day first.
What about the Burson vividV6 I have? I can lend you them if you lend me one of your Op amps, maybe the Classic v6!!
I'd be excited to try the Classic with the Spark OS in the two different positions. I think I would prefer the vivid, but I want you to try them too.
A Picture,
Portable balanced DX7 PRO without the case for Testing purposes! Discrete op amps sound great portably. I'm Swinging at 'em with the vivid!
Thanks Topping and Burson. This Is INDEED vivid. From the DX7 pro 9038.
The vivid is basically perfect. I listened for maybe around 8 hours on the go with the stock lme47720 over the past few days and the vivid is more Vivid indeed. . What a relieving upgrade for the HD 800 over the IC op amps...
Edit: The vivid is so great. I'm way happier... this is also the best I have heard the HD 800 sound so far. It is especially evident on the treadmill checking on the captioned telivision and reading the magazine etc at the Gym. I think if the 3602 are as good as this I'll be really impressed. The percussion. Sound effects and especially bass are preferred
The DX7 Pro is ALSO now able To overdrive the headphone Bass in some songs, a feat that it was not capable of doing before the V6!! 200MW is a lot into the HD 800... only at the Maximum setting though. When turned down one notch it is perfect.
And I will note that it really is vivid. An excellent upgrade; This op amp is making the 9038 Pro signal really Shine when compared with the 47720!
Very happy with the audio.
To IC op amps as buffers for the powerful ad8397 i can report that the discrete product is less fatiguing in the highs and the sound is safely improved, if only slightly (this isn't that slight), the appreciable difference is both marked and tangible.
Did I say the vivid v6 discreete op amps run warm? I am grateful that the Burson Vivid v6 can be upgraded easily in the DX7 Pro
https://tidal.com/track/63886369
https://tidal.com/track/79290313
https://tidal.com/track/4527434
https://tidal.com/track/144319231
