Topping DX7 - DAC and balanced headphone amplifier
Jun 18, 2018 at 4:16 PM Post #271 of 468
I recently purchased a Topping D50 and am running across the exact same issue. Seems to work great with usb from computer, but the optical from TV occasionally drops the audio signal, and sometimes very frequently. Did you ever figure out a solution? Love this DAC and would hate to return because of this. Thanks.
So glad to find someone else with this issue! Unfortunately, no solution found. Every single thing I’ve tried doesn’t mitigate the issue for long. This issue needs more awareness, especially if it’s affecting multiple Topping products. Topping themselves don’t seem to have any interest in resolving this for customers.
Jun 18, 2018 at 5:07 PM Post #272 of 468
I tried that yesterday after hooking up the DX7s with my speaker system. My Samsung TV seems to be sending a continuous TOSlink signal at 48 kHz without interruption, at least when watching TV via HDMI from my XFINITY DVR.
Can you guys add more details about your exact setups?
Jun 18, 2018 at 5:36 PM Post #273 of 468
Primary use for me is gaming:
TV: LG B7 OLED
Systems: Xbox One X/PS4 Pro
Connection: HDMI to TV, TOSlink out to Topping DX7
Sound format: Stereo PCM
I notice that it's much harder to trigger this issue when using a direct optical connection from the console to the DX7, but I was still able to experience it in some instances. It's completely random when it occurs through the TV. Sometimes it's several times within a few minutes, sometimes it's spread out and doesn't happen for 5-15 minutes. It really just depends on the audio that happens at that point in time. I think it particularly happens when there is a large fluctuation in dynamic range, but not entirely sure. Using TOSlink out from the TV with the same setup doesn't cause any issues with any other optical device I have, only the DX7.
Jun 19, 2018 at 12:00 PM Post #274 of 468
Here's the response I got from the amazon seller, it's similar to yours: "For your questions, please kindly note we have already contact with TOPPING, their technician said it's because the D50 has added a function of slowly increasing volume to prevent sudden access signals that scare people or damage hearing. There are some television and airport fiber signals that don't match it, so it will sound intermittently."
TV: LG 4k Smart TV (not sure model)
Receiver: Pioneer VSX-D1S
Speaker: DCM TW3
TV -> DAC via optical -> Receiver via rca -> Speakers
I also have a cable box (Spectrum) hooked up to the TV. I've tried Netflix/Amazon on the smart tv and regular cable. All have intermittent problems. I was watching Entourage on Amazon the other day home sick and I blasted through like 6 episodes with no issues, than it glitched 5 times in the next 20 minutes. It's completely erratic.
The DAC works fine through the USB from my desktop to the receiver. It seems to also work fine from the coaxial from my dvd player, although I've only watch 1 movie so far.
I'm guessing its the LG TV based on the response from the vendor, and the fact that both of us with issues have LG.
Jul 1, 2018 at 2:04 PM Post #275 of 468
Hey guys, i was switching usb cables and and then i put it back in and suddenly sound dissapeared... Tried turning it on and off, reinstalling drivers but nothing is working... what could be going on? Everything seems working but there is no sound from unit.
Many thanks.
Jul 1, 2018 at 5:48 PM Post #278 of 468
Many thanks.
Something like that happend to someone on Massdrop as well, although when switching headphones: https://www.massdrop.com/buy/topping-dx7s/talk/2112426
For him, this worked: "I had to completely power off the device with the cable removed and to wait a few minutes so all charged electricity to disapade. I turn it than back on and it was working again."
Jul 2, 2018 at 1:28 AM Post #279 of 468
Hey thanks, i did same thing 1 time but whitout waiting, didn't worked. Next time i just turned it off with remote control and waited for a few minutes while Taking my headphones off the output. Then I powered back Topping from remote control, kept switching between inputs and settings. Later on I put back Headphones into Xlr output and it worked perfectly. Don't know what I did to bring it back...
Jul 4, 2018 at 9:08 PM Post #280 of 468
May be somewhere in this thread it is has already been answered, but I couldn't find it. Is there someone who owns both the Jot and DX7s and can compare their sound quality with respect to HD 650?
Jul 16, 2018 at 7:55 PM Post #281 of 468
Does the DX7s have a mode where the XLR line out is on fixed volume and the volume knob controls the headphone out only? I'd be running it into a monitor controller and would prefer fixed line out.
Neither the manual nor any of the previous 18 pages were 100% clear about this.
Jul 16, 2018 at 8:07 PM Post #282 of 468
Nope. I wish. The volume, if controlled, is probably controlled at a central place, and so can't be switched between front and rear outs. You get DAC mode (100% rear, 0% front), DAC+HP mode (X% rear, X% front), and HP mode (0% rear, X% front). Basically, one central volume control + optional muting relay for front and rear.
Jul 17, 2018 at 10:04 PM Post #283 of 468
i got a friend that wants to get into headphones, but not fully into it so I was thinking the cheap schiit stack, then I came across reviews of this. Would this be a better recommendation for a starter dac/amp? I was also thinking about the ifi micro black label if he needed something portable to take between his house and his office.
Jul 27, 2018 at 2:47 AM Post #285 of 468
Some measurements DX7s vs Jotunheim:
https://audiosciencereview.com/foru...s-of-topping-dx7s-dac-and-headphone-amp.2378/
vs..
https://audiosciencereview.com/foru...dsd-black-label-dacs-and-headphone-amps.3717/
In short..Jot has much powerful amp, DX7s has better DAC.
