califmike33
Member of the Trade: DIY Modder
- Jan 14, 2017
It just seems that you either get a very postive comment or a very negative one. It is really hard to come to any conclussion. I've read it all and am not any wiser. Someone mentioned a problem, another confirms, then you get to people who don't know what the other two are talking about. Then another problem, same story.
The conclussion I got is that the DAC is harsh, USB is rubbish, you have to buy an expensive PSU to be able to reduce the harshness a bit, but it never really goes away. The DAC sounds digital and not pleasing, filters are pretty useless, OLED screen will fade away making the unit useless... I can go on.
Yeah I just started hearing about this stuff a couple weeks ago on here and it's like I don't like to get involved in these conversations because I hear nothing wrong with mine.
I bought the recommended power supply off of Amazon I forgot which one it is I don't have any issues.
I hear no harshness vocals mid-range sound clear crisp I don't know where all this stuff coming from because I hear the exact opposite of what people are complaining about.
I'm going to try hooking it up through Optical and see if there's a difference because I'm happy with it just the way it is but just out of curiosity I got to try it.
I've got this topping D50 plugged into the back of a s*** audio magni 3 as my amp.
Then it's running to a pair of JBL 306p powered monitors and my source is Flac files on my Android phone plugged into the USB part of the DAC self fabulous absolutely fabulous I have zero complaints.
