IS2 mods look possible, I was thinking about taking the IS2 signal from D50 XMOS chip to the 9038Pro in the UDA to see how the Interface is influencing sound but didnt bother, almost everything is clearly marked with a test pad in the D50 so there is endless potential for mods. Im thinking about upgrading DAC clock next, or replacing output opamp with a more powerful amplifier, enough to power headphones directly, it may be a simple as taking the input of that op amp directly to a headphone amp, that is if the signal doesn't need too much gain.Holy macaroni, Acke!
What an amazing franken-mod!
Are you able to figure the I2S signal lines from D50's USB XMOS to the DAC chip? I noticed I2S markings on some test pad.
Perhaps a great mod to upgrade the USB input is to franken-mod it with Luckit WaveIO as the USB receiver, and output I2S to D50 (or UDA).
It looks like the UDA uses OS-CON caps for the DAC chip. This is part of the magic. Lampizator's old site and DIYaudio is full of amazing mods to replace digital circuit caps with OS-CONs. Perhaps if space allows, replaceing D50's DAC chip caps with OSCONS could bring it closer to UDA's sound as well.
I didnt know about OSCON caps and that they could be an influencing sound, they looked just like normal electrolytics, this could be the next step in modding. The D50 DAC chips have very small ceramic caps, I was thinking about replacing them with PP caps but they are a lot buliker for the same capacitance, OSCONs could give a huge boost to capacitance in a small package. could you share a link to those mods?
