Tin Hifi P1 impressions
post-15147610
Post #721 of 1,141
fericske
An attempt to create resonance chamber. Sound became warm and bassy, lost crispiness and air. Didn't like it but if you want to try more bass why not.
This is what I talk about. The seating mod.
Just forget that eartips. Too tight, degrade the soundquality. Use the P1s foam, or try different tips, they have not less diameter than the nozzle. No any P1s silicon works well.
Fatdoi
"Imo driving P1 is like driving a 200ohm full size HP... And it gives the sound of full sized cans when driven via desktop amp... But YMMV"
Agree. Weeks I didn't use my full sizes, because I get full listening experience with P1, like with a can. (Final Sonorous 6, Quad Era1)
Reactions: bgtip
post-15147938
Post #724 of 1,141
Tysun
Singapore/Malaysia
Singapore/Malaysia
Fixed, used 2 tips and put them together so it is now longer. foam tips and longest/biggest silicone tips put together. If i use 1 silicone tip the soundstage is just between my eyes but with these combo tips the soundstage is now a 10 cm wider than my ears, close to a good open back headphones and the bass is much more present and even rumbles, to the sub bass area too.
Now not selling hehe
I tried what you did, I failed to 'implant' silicone stem into foam.
post-15148231
Post #725 of 1,141
Terozzzz
Finland, Helsinki
Finland, Helsinki
Age
47
It will go in, just push and turn at same time. So much that the red part is half in the foam one.
post-15148305
Post #727 of 1,141
trivium911
Canada
Canada
Can a wm1a power these iems effectively?
perhaps out of the balanced...all they say is 250mw at channel...at what impedance though? My fiio x5ii which i just sold had 430mw @16 Ohms where as the DX120 is 400mw @ 32ohms. I imagine the DX120 has much more power @ 16ohms for example and the fiio less at 32 ohms.
post-15148346
Post #728 of 1,141
Charlie Norwood
Previously known as Infinity Knives
NYC
NYC
Website
open.spotify.com
Effectively? Yes. Properly? Nah. They will get loud coming from the WM1A but will be missing dynamics, especially on the low end. If you don't care about bass - you should be okay though.
post-15148364
Post #729 of 1,141
gazzington
Wales
Wales
Oh, I do care about bass. Basically, if I'm not using an amp with a dap then best not bother. Possibly my n8 would power them though
post-15148512
Post #730 of 1,141
Charlie Norwood
NYC
NYC
Website
open.spotify.com
LOL a WM1A and n8? Nice... Yeah the Cayin should be a good fit with the p1 (I have an old c5 laying around that I should test the p1 on). I'm currently using the E1DA PowerDAC v2 which puts out 600mW@32 I believe and although there isn't much headroom after applying EQ (I think I'm around -8dB volume in the app) it's driving the P1 quite nicely.
post-15148715
Post #731 of 1,141
captblaze
Blazin it up in the land of Lincoln
on its own the WM-1A doesn't have enough grunt to really wake up the P1s, but paired up with an Oriolus BA300S and now they sing
post-15149293
Post #732 of 1,141
dogears
Philippines
Philippines
P1's arrived. Listening to them now with the stock tips... pretty impressed so far with the natural timbre... and the bass is there :)
Reactions: bgtip
post-15149772
Post #733 of 1,141
davehutch
Website
www.hutchinsonphotographic.com
Has anyone here used both the Radone ES100 AND the iFi xCan to drive the P1s?
If so, do they benefit from the increased power available form the iFi?
I know that in theory they should but please only answer if you've actually tried both devices to drive them and can compare.
I'm thinking of selling my desktop amp to buy an xCan
Thanks
post-15150057
Post #734 of 1,141
trivium911
Canada
Canada
Does anyone know how the bass on these compares to the hifiman 400i? I know alot of people said the bass is lacking on both the 400i and the p1's...I actually find the 400is bass to be spot on and rather addictive. It's there, its present but you don't notice it...it doesn't bleed over.
post-15150219
Post #735 of 1,141
captblaze
I own both, but to me it is an apples and oranges comparison. Over ear open back vs in ear doesn’t directly compare.
I will say with the right amp and good eq they both sound better than without
