Tin Hifi P1 impressions
post-15155311
Post #751 of 1,170
Charlie Norwood
Previously known as Infinity Knives
NYC
NYC
Website
open.spotify.com
Just received the P1. I noticed some clicking sounds on the right earpiece (also on the left one, but far less frequent) when listening to certain songs.... Should I be worried?
False alarm, turned out to be the songs.
Missed this when you posted it but glad you figured it out! Clicking sounds are almost always a sample rate issue, either during digital compression of the song file, or, and if you hear it with more than one song, it's a sample rate conflict between devices.
post-15155349
Post #752 of 1,170
Charlie Norwood
NYC
NYC
Website
open.spotify.com
the timbre! <3 <3 <3
@CharlieNorwood, the ridge is not secured if the tip bore has no 'anchor' whatsoever... it's so smooth and slippery! :p Will check blues today.
Maybe try a smaller bore tip? I'm using tips that also work on Sony's, they are a little tough to get on, but once they are on they are extremely secure.
post-15155433
Post #753 of 1,170
cenix
Yes, I'm glad that my initial thoughts were wrong. Really don't want to send these back due to some defects. Btw, the box your P1 came with, did it have grey or black foam inside? I think that the batches they produce (using black foam) currently are more hurried with less quality checks. Mine also didn't come with the foam tips like everyone else's and the box was practically falling apart. Lots of glue residue outside of the box etc. Or, it could just be my luck ofc (I ordered from Linsoul, via Amazon Germany).
Linsoul does have good customer service tho. When I contacted them, they immediately offered to send me new ear tips.
post-15155554
Post #754 of 1,170
dogears
Philippines
Philippines
Will keep that in mind Chief. Thanks
Reactions: Charlie Norwood
post-15155763
Post #755 of 1,170
cenix
I'm currently using Sony Hybrids (genuine ones). They are masterful with trance at least. I have tried a bunch of tips, like the Dunu Spinfits (CP100) and various other no-name tips, but the hybrids sound the best to me and brings the bass forward.
Before using these, the Vsonic GR07s were my main IEMs. It's ridiculous how much of an improvement this is, despite not spending a lot more on it (I spent around 110$ on the GR07s back in the days)
post-15155802
Post #756 of 1,170
Fatdoi
Australia
Australia
Researching new Hiby R5 if it has enough juice to power it... Quoted 1040mW@16ohm... Should be OK?
post-15157102
Post #757 of 1,170
Charlie Norwood
NYC
NYC
Website
open.spotify.com
1040mW x2 will for sure do it. If it's 520mW x2 then IMO will also suffice, you'll just probably need to get close to max power if you apply any EQ.
The R5 looks pretty interesting all around though. If you go for it, please drop some impressions here. Been looking for a DAP that does streaming apps + a good amount of power + eq + bluetooth AND plays nicely with the p1. Would've preferred 2.5 to 4.4 but now I'm just splitting hairs.
I'm a dedicated iPhone user for now - might switch to a ROG at some point idk. But even though iPhone does AAC really really well, the lack of global EQ and the higher-res bt codecs can be a bummer.
post-15157904
Post #758 of 1,170
Fermus4
Usa
Usa
Got some jvc spiral dots to compare to symbio w and my hybridized spinfits. Shorter tube length doesn't work great with comfort, less bass due to less than ideal seal for me. Spinfits with some mack's extra soft foam plug material around still by FAR sounds and feels best for me. You guys should try it, won't be disappointed.
https://www.amazon.com/Macks-Ultra-...=1567208335&s=gateway&sprefix=mack+ear&sr=8-4
post-15157912
Post #759 of 1,170
dogears
Philippines
Philippines
^i’m scouting for cp155 or cp500. it’s ear canal dependent so must i just have to try all lol
post-15157917
Post #760 of 1,170
dogears
Philippines
Philippines
btw the double flange didnt work for me
small ears/canals here
post-15157929
Post #761 of 1,170
atomd
OK I've tried a bunch of different tips I had lying around. I'm going with some comply foam mediums for now. They seal well and are very grippy. Normally that wouldn't be my pick for just any iem but it is the best out of what I have for these. I don't want to knock the P1 but to me it is definitely a "fills the niche" iem. It seems really dry and analytical. Detail is insane for the price. I think that as long as you know this going in you will be happy. For a "do it all" iem they would be a bad pick for me. For one genre these will knock it out of the park but for another it might be boring for some. I think they have their place and I will keep them.
Reactions: backdrifter
post-15158205
Post #762 of 1,170
oneula
hawaii
hawaii
how much power do you need to really bring these to life?
I have the fiio A5, Xduoo XD05, Monolith THX portable amp, and Topping NX4 DSD
Seems like it may need more power like from a desktop amp to really shine.
Any suggestions?
post-15158285
Post #764 of 1,170
Fatdoi
Australia
Australia
Any suggestions?
Imo if a dap can power HD650 should be enough for P1
post-15158535
Post #765 of 1,170
dogears
Philippines
Philippines
sansa fuze (yes the good old sansa fuze) -> fiio E6 (yes the good old fiio E6) -> P1 (yes the planar IEMS) is sounding great for me :)
Reactions: captblaze and bgtip
Users Who Are Viewing This Thread (Users: 3, Guests: 2)
