wen amarra for tidal is out will Fidelizer Pro+amarra for tidal give me even better sq or do i only use one software?
if yes with one?
Back to basics:
Fidelizer= computer optimizer
Amarra/Roon= Player software
Asio Bridge= Asio speaking software, ie. bit perfect playback for players without this option...or exclusice mode if you want.
Jplay= Audio enhancer that will give you better synergy between computer and hardware depending on setup. Doubles as a memory player (Jplay mini) or streamer (Jplay streamer) together with minimserver/ Kazoo/Bubble that make you control the player with a tablet with high end performance...but requires Windows 8.
Audio Optimizer= Audio enhancer for Windows server only. Together with Jplay you can easaly create a double PC setup with one control PC and one audio render PC.
AirServer= Software that enables airplay on Windows/Mac computers with lossless quality. Requires 5 ghz network to funktion properly.
*As long as you use a computer Fidelizer will bring the best audio performance out of your computer, despite other softwares. So far it is the best one around.
* Players will only "hi-jack" Tidal player and give you better user experiance and at best give you bit perfect playback and player related audio performances.
* Asio speaking software is just needed if the players is NOT bit perfect, ie. Not bypassing the windows sound mixer. If you want you can use Jrivers WDM driver for similar results.
* Jplay will be useful for enhancing the performance between computer and hardware. So far it is the best one around.
* Audio Optimizer might be the best solution together with Jplay and Fidelizer...but requires two computers. One wind Windows 7 and one with Windows Server OS.
* AirServer will give you the abbility to use send lossless audio from your iPad to your computer with the soundcard of your choice...eg choose VB cable for Tidal.
Hopefully this gave you a brief insight in what the software does for you. What you choose is depending on what OS you have got.
