No Desktop player? How can i enable wasapi with Tidal, through the browser player? The options are terribly limited.
One way is to use Jplay6 together with Asio Bridge. Not free, but will end up with a big sound improvement.
any thorough explanation available on how to set this up?
It is actually enough to just use Asio Bridge..and it is donation ware. Should work with Wasapi as well. Download Asio Bridge, set VB cable as your computer sound device, open Asio Bridge and set your Wasapi driver as the device.
Edit! Download Fidelizer 6.7 free as well and run it before you start listening...and you will have a pretty good improvement for almost nothing.
Well, you should try Jplay with Asio Bridge. Without Asio Bridge you will never have a bitperfect setup with Tidal. Just make sure that the sound output is set to 16 bit/44100 Hz (Cd quality)...and check that your sound slider in not working (so you know that the setting is correct). Asio Bridge will in my opinion improve Asio performance on Foobar as well...and does'nt hurt to try with wasapi.
Edit! Jplay6 is the one you want. If you have tried 5x versions...you will miss out on the major improvements with Jplay (ie. The DAC link feature).
does the dac link feature only work with a dac connected through usb? my bifrost uber is connected to my sbz via optical out.
i cannot find that option in jplayer6
Yes, the DAC link feature should work on your DAC with optical out as well. I know that Shiit DAC's have reports that it only works with Wasapi with Jplay...and you should check that you have the latest driver installed. The DAC link is really a buffer connection were 700 Hz= 64, 350 hz= 128 etc. Make sure that the driver sample on Shiit is corresponding to Jplay DAC link.
ok i think i have it figured out.
I run asio bridge, and turn asio on? when i turn it off i hear no difference.
for jplay, i have playing via asio (my sound card)
in windows speaker icon, VB is selected as playback, and in recording, i must listen to VB with spdif out as the playback device?
This is the only way i can get any sound to play, and am not sure if the setup is correct.
If Asio Bridge should work the player output and the computer output must have the same bits and Hz. Since Tidal output 16/44100 Hz the VB cable PC output must be the same to work properly.
yupp...did all that, no sound if i select ASIO bridge as my default playback device with those particular settings, unless i "listen to device" for ASio brindge (VB) in recording tab of windows audio and select my optical out as the playback.
