FLAC is FLAC, not possible to be equivalent
Tidal Lossless Streaming
- Thread starter Baroninkjet
I see.... like my comment...FLAC is FLAC, not possible to be equivalent
Chris Kaoss
Guess you question is, if Tidal streams in a proprietary lossless codec, similar to FLAC.
But why should they, bc FLAC is "free"?
No need to but extra work on another codec, imo.
Yea I think so. I wanted to know whether 44/16hz hifi Tidal is FLAC or FLAC equivalent.Guess you question is, if Tidal streams in a proprietary lossless codec, similar to FLAC.
They stream loseless 44.1kHz/16 bit stream in FLAC. End of the story.No link because its verbal.
When I mentioned pure FLAC I mean direct physical rip CD as oppose to streaming 44/16hz on Tidal which I wonder if its actually FLAC or just FLAC equivalent.
Regarding "physical rip CD" that's another thing.
I heard and even pointed out in this thread that some music can sounds much worse than what you can have on CD - it was a 1999' album from Static-X.
New releases though might sound better than on their CD equivalents IF music's publishers follow TIDAL or other streaming providers guidelines on how loud they should upload their music, and considering that on their CD releases they will skyrocket volume like before.
There is no rule if streaming sound better or worse - it is purely album dependent. Having "TIDAL Masters" label does not guarantee that it will sound at least as good as the CD version.
rlw6534
Tidal says it streams in FLAC at CD-quality, at least for the HiFi tier. That makes sense as FLAC is lossless and but takes less bandwidth than raw PCM. The FLAC codec supports multiple bitrates and bit depths (as well as MQA) so simply saying a file (or stream) is FLAC doesn't tell you the quality of the audio. A FLAC encoded CD will be 16/44.1 because that's what the CD source provides. FLAC can certainly be high-res as well and also preserves/supports MQA (if the MQA information is present). So FLAC can be 16/44.1 or it can be 24/48 MQA that decodes and renders to 768 kHz (with a supported DAC). - and many other possible bit rates and depths.
rkw
I think your question is whether Tidal HiFi is lossless streaming. Yes it is lossless. As others have pointed out, if it is an MQA encoded album (Tidal Master), it won't have the same data as a rip from CD.Yea I think so. I wanted to know whether 44/16hz hifi Tidal is FLAC or FLAC equivalent.
Please stop using the term "FLAC equivalent". It doesn't make sense.
gimmeheadroom
Well MQA is lossy, hires compression that requires bitperfect (as you mentioned). It's one a kind
Ok, so Tidal Hifi and CD rip are considered as FLAC ?
No FLAC is a format..
Yes then. So let me rephrase, equivalent to CD as well since 44/16hz ?No FLAC is a format..
right, but FLAC can also be higher quality.Yes then. So let me rephrase, equivalent to CD as well since 44/16hz ?
Higher quality such as what ? Like for instance ?right, but FLAC can also be higher quality.
Can I simply say Tidal Hifi is FLAC ?
yes, Tidal uses FLAC format. and streams in 16bit 44.1Higher quality such as what ? Like for instance ?
flac can be: ex: 24bit 192
Yes that I am aware of. Because some say its not FLAC.yes, Tidal uses FLAC format. and streams in 16bit 44.1
Total: 7 (members: 0, guests: 7)
