gimmeheadroom
Hi,Hello everyone.
I just started my trial with TIDAL.
Did anyone encounter low quality music even labeled as "MASTER"? I had that problem with Spotify that music sounded bad and much worse to the originals regardless of the "Extreme" quality setting.
I am referring to "Static-X - Push It" song. It's from 1999 album labeled as "Master". Since I have only Xonar STX I listen to "Hi-Fi" quality although I can hear artifacts in high frequencies very similar to what a lot of 128kbps mp3 have. I tried "Master" quality but it doesn't help.
I recorded "Wave output" with Nero Wave Editor and spectrum is not cut - full like on a normal album. Although sound is much different to what I have on my retail CD ripped to my computer. What's interesting that "Normal" quality has a better spectrum than "High". Doesn't affect though very poor quality of that song.
Did anyone encounter similar problem?
I just did a search on Tidal and there are a few hits for a Master for this song. I'm playing it right now over a DAC with full MQA support. It sounds like a good recording to me. I don't notice any artifacts but there is not much high frequency content on that cut. I'm listening to the next one, I'm with Stupid, also sounds fine. By the way, this album is green (unknown provenance) as opposed to blue (verified provenance). The weird thing is, with MQA hardware, I'm getting a 44.1/16 bitstream but when I change to let Tidal desktop do the first unfold, it switches to 44.1/24. This is surprising and I don't know if it indicates a problem or not. The way I thought it is supposed to work is that hardware MQA gets you the full unfold but software only the first unfold. So I expected that the MQA DAC with MQA passthrough enabled on Tidal would have gotten me the higher bit depth, but it was the opposite.
On a non-MQA DAC, the songs also sound fine and on a pair of HD 25s anyway, I heard no difference between MQA passthrough and letting Tidal do the first unfold.
Since you're having the same problem across services that have totally different types of encoding, I have to guess there is something wrong with your setup. And by the way, my brain hurts. You owe me a beer or two for having to spend 12 minutes listening to the headbanger music you asked about. I'm too old for this stuff
This is the link to the version I was checking https://tidal.com/browse/album/4082261
